Eoi Rb26/30 Full Setup
hey fellas I'm thinking of going a different setup in my car.. so I have my current setup as an EOI
RB26/30, RB26 head on rb30 bottom end...
stock RB30e bottom end, GTR oil pump, 8.3:1 compression.
genuine nissan head gasket was used, brand new head studs also
stock GTR turbos, split aftermarket dumps and aftermarket front pipe
R34 GTR injectors
comes with-
-complete motor
-loom
-Apexi power FC and hand controller
-all intake piping, airflow meters, blitz pods custom airbox etc
Is still in car and can see running. runs perfect. it is very very torquey and responsive. sounds awesome!
Motor hasnt been tuned but did make 305hp at just under 11 psi untuned, is getting tuned on 13 july by Matt Spry
Price- 5k before 13 july 5.5k after
I may be keen on motor setup swaps and cash my way... currently it has a VL turbo box behind it and a single peice tailshaft with an extreme button clutch. so if a complete driveline swap would work, I'm keen!
Located on the Sunshine Coast in Qld
pic
Edited by craigy32
 Share
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
