GENUINE NISMO R32 GTR.
Build number 219 out of only 500 produced by NISMO.
Original 69,xxx km.
Complete respray in Midnight Blue (TH1)
NISMO Edition specifications include:
Nismo upgraded turbines (T25/T04B 0.64) with metal turbine blades. This engine was known as the 'PLASMA RB26DETT'.
Nismo lightweighted - 60kg lighter than the stock GTR.
ABS not fitted
Rear windscreen wiper not fitted
Nismo grounding kit
Nismo 320klm speedo (original fitment)
Nismo side skirts
Nismo N1 air ducts in front bumper
Nismo bonnet splitter
Nismo rear wing
Nismo short shifter
Nismo braided brake lines
Nismo fuel pump
Nismo headlights
Nismo leather gear knob
Air Conditioning fitted (this was a no cost option) -some buyers preferred no air conditioning for weight saving purposes).
The following parts are also fitted:
Apex'i Power FC
Blitz Dual Stage Boost Controller
HKS Turbo dump pipes & front engine pipe
Metal Race Catalyser
Kakimoto Regu 06 Cat back exhaust system
ORC Twin plate clutch with lightened flywheel
HKS Hipermax coilovers
Adjustable control arms
New suspension bushes all round
Cusco front and rear strut braces
Tomei sump baffle
Tomei adjustable camshafts
JUN cam pulleys
Sard fuel pressure regulator
N1 oil pump
Trust oil cooler
Blitz Technospeed Z1 18" x 10" alloy wheels with new tyres
DBA 4000 front & rear brake rotors with new brake pads
Cusco master cylinder stopper
Recently fully serviced with Nissan engine refresh kit including all new gaskets and all fluids changed. New timing belt, new NSK/NTN idler pulley & tensioner. New genuine Nissan cam seals. New genuine Nissan front main seal. New Nissan water pump. New Nissan thermostat.
Quicktrak monitoring alarm
Tuned to a reliable 312kw at the wheels @6300rpm. Dyno graph available.
Car also comes with the original steering wheel in very good condition, standard R32 GTR wheels and standard suspension parts.
Regularly maintained, engine oil has been replaced every 3,000 Klms.
12 months registration included
$24,500
Located in Sydney
0423 885 535
Matthew
Edited by mattblack
https://www.sau.com.au/forums/topic/276864-genuine-nismo-r32-gtr/
all Nismo's were built in 1990.
Yes i still have the original cams.
boost was at 19psi in mid and tapered off to around 17 up top. Also have the boost controller options at 10, 13 and 16psi. Power is at all 4
reason for selling is simply that i want to get an R34 GTR. Its a tough decision as i still really enjoy the 32 every time i drive it. Ideally id put a car cover over it and keep it but my wife says thats just not going to happen so it has to go if i want another car.
here's another pic:
