  • Hey all, I have to clear out some room for the up coming projects so I have decided to part with some of the things that have
    accumulated in the work shop! The pics below are for your viewing pleasure,so if something catch's your eye feel free to
    PM me.The parts are from a 32GTR or a 33GTR V-SPEC. I am located in Adelaide, South Australia. I am willing to ship
    items so P&H will be at buyers expense!
    Cheers HULI
    2 x RB26 blocks (one has some grooves in bores from ring land failure and the other block is basically perfect)
    Slightly grooved block $200 (can be honed out)
    Perfect block (V-SPEC) item $600
    RB26 crank (larger oil pump drive snout) $400
    RB30 crank + girdle $80
    2 x RB26 girdle + crank scraper + oil pick up $150 each
    4WD GTR sump + gears + baffle plates (Off 33) $500
    V-SPEC turbo's (no shaft play and don't blow smoke) $800
    32GTR turbo's (no shaft play and don't blow smoke)
    R33 head (has cams, valves, shims, springs etc) $1000
    Fuel rail + regulator + injectors $350
    Fuel rail and reg only $80
    Throttle bodies + linkages $350
    Intake plenum $100
    Injector plate $400
    Pistons and rods (set of 6 but one has ring land failure) $150
    Cam gear backing plate $80
    Stock cam wheels $80 the pair
    2 x water pumps (stock) $30 each
    2 x AAC valve assembly $150 each
    CAS + CAS support bracket $250 (crank angle sensor)
    Coils (set or 6) + brackets $100
    Odd pipes,exh manifolds, elbows, O2 sensors,2 x y connecting pipes $5-$40
    2 x Oil and water lines $100 each set
    2 x oil cooler assembly $150 (one has magnetic Drift filter)
    3 x Harmonic balancer (2 from 32gtr and 1 from 33 Vspec) 32 ones $50
    33 one $100
    2 x Alternators $100 each
    2 x idle regulator valves $100 each
    Uncut wiring loom (complete from computer to battery) $450
    2 x power steering brackets $20 each
Cheer HULI
th_06282009184.jpgth_06282009188.jpgth_06272009141.jpgth_06282009182.jpgth_06282009179.jpgth_06282009178.jpgth_06282009175.jpgth_06282009173.jpgth_06092009126.jpgth_05302009088.jpgth_05302009089.jpgth_06282009152.jpgth_06282009154.jpgth_06282009155.jpgth_06282009156.jpgth_06282009157.jpgth_06282009158.jpgth_06282009159.jpgth_06282009160.jpgth_06282009161.jpgth_06282009163.jpgth_06282009162.jpgth_06282009164.jpgth_06282009166.jpgth_06282009167.jpgth_06282009169.jpgth_06282009170.jpgth_06282009172.jpg
https://www.sau.com.au/forums/topic/276870-rb26-engine-parts-sale/
  • Replies 41
Hey mate, willing to seperate pieces off the throttle bodies? need the top and bottom balancers/water channel pieces aswell as the vacuum bar
Cheers
Sorry mate, complete unit only! worthless to me otherwise!
POWER STEERING BRACKET ****SOLD****(igpmg)
is the price for both turbos?
Sorry Guys, the V-spec R33 GTR turbo's are $800 the pair
the R32 GTR turbo's are $500 the pair
the twin set-up for either R33 or R32! SORRY AGAIN!
R32 GTR HARMONIC BALANCER ****SOLD**** (sickr33)
Lots more great parts available! Send us a PM if interested in any of this stuff!! OR even call 0400262578 anytime!
Cheers HULI
PM's sent.
4 interested parties in the blocks!
harmonic balancer back up for grabs- 2x R32GTR and 1xR33GTR vspec.(no response from buyer)
alot of interest in loom also!
If you require any of the remaining parts, be quick!
Send me a PM if you require added pics or just want a question cleared up!
Turbo's come with everything from exhaust manifolds, dump pipes, O2 sensors, heat shields!
2 interested parties for injectors!
4 interested parties for both blocks!
Will not hold items anymore!
FIRST IN BEST DRESSED!!
Both power steering brackets ****SOLD*****
Merging intake pipe ****SOLD**** ONLY ONE REMAINING!
VSPEC Block ****SOLD**** (Junga)
R32 harmonic balancer ****SOLD**** (sickr33) ONLY ONE REMAINING!
Engine mounts ****SOLD**** (sickr33)
Crank main gear ****SOLD**** (sickr33)
VSPEC R33 harmonic balancer ****SOLD****
ALL OTHER PARTS STILL REMAIN! SEND US A PM IF YOU REQUIRE THESE PARTS!!
CHEERS HULI
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
