Greets all.
As some of you may know, Payback21 had bought himself a BNR32 front cut that we were going to shoehorn into his HNR32 (Gts-4).
Well the build is now finished after 2 weekends worth of work and we thought that we'd share the experience to let anyone else who's interested know, what we did and how we went about it.
Firstly, the arrival of the front cut.
This is what the girl looked like before we tore her apart.
Now we get down to the nitty gritty. We jacked her up and placed her onto stands, then removed the usual items but also the front fenders. The reason for the removal of the fenders was for easier access to feed the wiring looms.
The way we wanted to go about the swap was to remove the sub-frame, engine, and gearbox in one piece from the front cut, and transfer the whole lot over to the donor vehicle.
And so it begins with a little help from my son.
Next we jacked up the front of the car and supported the sub-frame with stands.
Now we removed the driveline items and supported the gearbox with a trolley jack.
Then we removed the bolts for the sub-frame and gearbox crossmember. Then we slowly lowered the sub-frame and gearbox down to more stands.
Next we jacked up the front of the car to a point where we had enough clearance for the complete setup to clear the bottom of the front frame. We used truck stands under the chassis to support it while we were moving the engines around.
We then transferred the trolley jack to under the sub-frame, jacked it up, removed the stands, then moved the setup out using just the trolley jacks.
At this point we swapped over both sides of the wiring loom because it's easy to get to everything with no engine in the way.
Now it's time to fit the 26, here's one we prepared earlier....
Now using a reverse system to the way we removed the 20, we slotted the 26 in lowering the car slowly and checking all of our clearances on both sides of the engine. As we slowly lowered the car to a point where we could still reach underneath, we stabilised the car then set about lifting the setup using the trolley jacks and aligning the sub-frame bolts, and gearbox crossmember holes.
post-15314-1246193409_thumb.jpg post-15314-1246193461_thumb.jpg post-15314-1246193554_thumb.jpg
Once everything was lined up and bolted in, we proceeded to connect all of the other pipes, tubes, wires, etc...
post-15314-1246193699_thumb.jpg post-15314-1246193741_thumb.jpg post-15314-1246193813_thumb.jpg
All wired up and ready to fire.
We primed the fuel line then turned the key......... First pop and she was rumbling away. This is how she was road tested :P.
Next, we wanted to install the triple cluster so out came the dash and we exchanged the GT-R wiring loom in. We wanted to fire the car up and get her running before we did this step in case there was an issue on fire up, there would be less wiring to track the fault down to.
All back together again and ready to rumble.
If anyone has any questions, feel free to ask.
See you on the next cruise!
https://www.sau.com.au/forums/topic/276871-payback21s-gts-4-rb26dett-build/
Very nice. Always quicker dropping the sub frame out.
Nismo plate on the firewall had me thinking you might have scored cams/turbos. The part number shows up as Nismo twin plate clutch which was probably fitted at factory.
That's a shite load of work in that time hey, well done.
great read mate, well done.
What I liked most was the thinking/planning ahead... just for simple things like incase there were probs in the future with the wiring, so you warmed the car up first while everything was out....
yeh sounds good in theory to start the car with the dash wiring out but wat happens if u start it and warm it up and it doesnt have oil pressure. yes u could hear that it doesnt sound right but its still always a good idea to be able to keep an eye on oil pressures
I probably didn't clarify what we did here. We left the original HNR wiring and dash in place while the transplant and fire up was being done. Once the start was accomplished and everything such as oil pressure was good, we road tested the car.
When we came back from the test and gave it the thumbs up, we then ripped out the dash and replaced the HNR wiring loom with the BNR.
I wasn't comfortable with doing the whole lot at once because the front cut was open to the elements before we got it and I didn't want to run the risk of tracing through three different wiring looms to find a fault.
As it turned out, all was good.
Hey Fellas,
The job went pritty straight forrward with the help of my good mate Allen.
Everything from the the front cut pritty well fell into place for the GTS4. Im very happy with how it all went.
Just got to replace the twin front pipes to 3" instead of 3 1/12" and shes ready for a cruise and dyno run. Ive got some other bits and pieces to tweak the girl up too, so i cant wait.
Feel like taking it for another rap around the block with the exhaust off. Its nice weather for it. :thumbsup:
UPDATE:
Today the front pipes and decat went in then took her for a spin. All is well with the car.
We took her back and decided to remove the restrictor then I placed the Mines chip into the ECU. BIG difference.
Anyway, Brett is a happy camper and if you have the means, I highly recommend the upgrade to any HNR owner.
hey guys nice job just wondering how much it cost roughly????
how much was the front cut and anything else you may hav needed???
cheers.
Greets man. The cut cost $6,500 with the Nismo gear. We didn't need anything else to complete the job.
Did you swap the sumps, as i believe the front and rear diffs will have different ratios now?
Yes mate, the ratios are different. Still undecided as to what to do but I believe that Brett is swaying towards leaving it as is for the time being.
With the torque split controller in the car, he can dial the difference out.
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
