1993 R33 - Nissan Skyline GTS-T
QUICK SPECS
Manual, Maroon, GTS-T, R33, 129,000kms, Asking $10,000
MODS
HKS Cat Back exhaust (on it when I brought it), Air Filter.
OTHER
I have Replaced water pump, timing belt, thermostat & ancillary belts, new plugs, new coolant also cleaned the idle control valve. This was completed at 120,000kms.
Machine brakes at 129,000kms, bleed the brakes also.
Everything works perfectly on this car, electronic windows, electronic mirrors, Air condition is icy cold (not that its needed YET!) heater, dash everything works as it should.
Car drives very well, runs standard boost and has since I have owned it, It doesn't look like it has been tampered with at all previously either.
Paint is in excellent condition and would come up really nice if I had the time to polish it. But I don’t unfortunately.
All in all I think this is a excellent condition skyline and worth every cent, I have never had a mechanically problem with it in the time I have owned it which is over a year, and it has never missed a beat, you don't need to spend any money on this car, Which makes me want to keep it but I just can't, I need the money to badly.
First to see will buy. Why buy a modded skyline only to be always fixing it?? Why not get a standard good condition skyline and do the mods, as they say you need a good foundation before anything else.
Please call or sms Peter on 0422070093
https://www.sau.com.au/forums/topic/276917-1993-r33-gts-t-skyline-maroon/
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
