  • Replies 43
read about this in the paper today...
this is the ad.
I actually liked it, its very clever, and you can tell its in a warehouse in a controlled environment off the street, as an expression of art. some people just need to harden the fuck up.
Yer this is what shits me. They took down the ad because it promotes hoon behaviour.
By the same process, they should ban all motor sport depicting fast/dangerous driving.
Australia is getting out of control with censorship. If you have been keeping track of the ALP cyber safety plan, you'll know what i mean.
Very Poor Indeed.
so based on what the gov thinks,
after seeing the add, i should now put paint jets into my wheelguards and hoon around painting the streets
i liked the add, poor decision :P
Protect the innocent minds of young drivers!
Haven't you heard the increased wheel spins in the evenings since that ad first aired!
Thank God for common sense parliamentarians making decisions for us!
Quick! The ad is on YouTube! Ban that as well!!
I just watched it and had to 5 wheel drift my office chair!
Farkin' useless bunch of oxygen stealers. Get some perspective.
Edited by iamhe77
Yes!
How funny would it be if you pulled up at the lights today, only to witness.........
A BMW Z4 drifting through a red light with paint spraying everywhere!
It could happen, surely the only reason why you buy a Z4 is it's ability to lose traction and create colorful art simultaneously.
Next time you see odd paint on the road, there is a fair chance it was a Z4 (Paint spray would depict extent of traction loss)
Lol, soon we'll have the Great Firewall of Australia, which is the internet censorship, no R rated games even though the average Australian gamer is 30 and now banning ads because they show "hoon like" behavior. HOW ABOUT YOU BAN ALL THOSE f**kING MOBILE PHONE/SEX ADS ON MIDNIGHT FREE TO AIR TV!
LOL, I'm not surprised.
When I first saw that ad I thought to myself "If that was a Skyline spinning paint to pretty music it sure as hell wouldn't be on TV". Guess they're not total hypocrites.
Still stupid though.
They actually used to have boob on those ads years ago, so it is toned down
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
    • Looked it up. It sounds so expensive lmao I'd rather not. Awwwww but I just love that sound
