Dead turbos were recently replaced with highflows and xforce dumps by an amateur (me). Giving it a thrash for the first time at the track today - in third the boost is normal (currently 13psi) until 6000rpm then it drops straight down to ~ 8psi. In fourth it the same thing happens at about 5500rpm. Happens every time like clockwork. Boost gauge just falls back to 8 and engine feels really soft. EBC has a greddy box in the cabin and a profec box in the engine bay....Any ideas what would cause this?
https://www.sau.com.au/forums/topic/276956-boost-builds-well-then-dies/
Yeah its a 32 GTR (look left :-)
The actuators came off the old turbos (which were working) but the spring in one did seem stiffer than the spring in the other. I do have two spare actuators, but i'm not sure of the condition.
So what do you think is happening? Could it be that when the wastegate opens it snaps open all way so bleeds off too much exhaust?
To test, i guess i should apply vacuum (or boost?) to each actuator and watch how the rod moves, right? What tool would I use to apply the signal and where do i get it?
BTW - thanks all for the input.
The service manual recommends using an air gun with compressed air regulated to 11-13 psi (testing pressure of the source first) and blowing it straight in the hose on the top of the actuator.
You also want to verify that it opens/closes all the way; without being able to see the flap and/or having a point of reference that will be harder.
I don't know much about your boost controller; does it have different settings for different gears or overboost protection?
Regards,
Saliya
Any damage to the engine when the turbos let go, and that would be stock turbos right ???
And at what boost?
Stock turbos, no damage to motor, 13 psi, conservative tune, 11.5 AFR. The turbos were probably 118,000kms old (supposed to be replaced at 100,000 according to Nissan).
Ok both turbo actuators are moving in unison, so it looks like they're ok.
The EBC unit is a greddy profec, I found some instructions HERE
So i guess i'll just go through the setup procedure again. It does have a safety feature that drops boost back down to stock level, so i must be hitting that.
Thanks again.
did the exhaust wheel happen to come off the old turbos at all? if so it may have damaged the cat. a mate of mine had a similar problem where boost was dropping at higher rpm. turned out to be his cat was damaged (rear section had broken off and turned sideways and was blocking the exhaust)
also to check the EBC, i would just disconnect it and try to borrow someones manual controller that is set to a similar boost pressure. if it still drops pressure it isn't the EBC
Yeah the wheel disintegrated, and i removed a fair bit of ex-turbine rubble from in front of the cat matrix (200 ci metalcat). There were no bits stuck in the front of the matrix itself, but i guess they could be lodged further down. I'll take a look at that if the EBC re-training doesnt work.
im putting my money on it being the EBC. especially if it is a greddy, I have a mate with the exact same symptoms at the moment. It shouldnt be the wastegate unless u are running stupid amounts of boost through the car. And if it is the actuators sticking the wastegate shut, shouldnt the boost be creeping up not down?
Id say put on a manual boost controller, test to see if it changes how the car drives, and if it is the EBC then look up how to properly tune the EBC. There are threads in here somewhere.
:P
Edited by lineskee 33
Has he tried re-running the learning procedure as per the manual i posted above? It says "this process must be done after the installation of Profec, and after any changes are made to the characteristics of the wastegate spring, or out put power of the engine (IE turbo size, intercooler)".
As far as i can tell in my case the Profec is working as designed and i'm just hitting the overboost protection because i've changed the turbos. I just didnt know this was required before i posted.
No he doesnt want to touch it. Sorry mate, i thought u had the newer model of the greddy ebc. with the profec B you just adjust the gain until the boost stops dropping off.
Are you able to increase the overboost value so that it doesnt kick in?
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
