hey guys iv got a small oil leak in my rb20det, it appears to be coming from the turbo side at the back, heres a pic;
the area i have circled is the highest point that oil appears to have built up, it then runs down the side, there is also some oil built up behind the engine(where the arrow points)
can anyone help me determine where this leak could possibly be and if so how i would go about fixing it?
https://www.sau.com.au/forums/topic/277006-oil-leakneed-some-help/
ive got the exact same leak too on my 33. had the gasket replaced by one workshop but there was still signs of leakage. had it double checked cleaned and tightened again by another workshop but it came back. my suspicions are its the oil line that goes into the block directly under and when there's air turbulence in the bay(ie driving) it throws the oil around. I can see the nice pool of oil down below infront of your gbox, mine looks exactly the same. I have yet to properly double check my hunch with a mech so i dunno but when i had it up on the hoist for a quick road worthy the guy came to the same conclusion.
are you referring to the oil line that runs from the block to the turbo? i replaced my gasket this morning and so far so good but ill keep an eye on it over the next few weeks.
  • 1 year later...
I have a similar problem. Except mine is towards the front of the engine. It doesn't seem to effect the performance of tje car at all and the oil pressure doesn't appear out of the ordinary. I'll check the rocker gasket and see. Hopefully that's all it is.
    • Noice Once exhaust leak is sorted post vids for audible sexy time The thing should be a laugh riot to drive
    • Nah, apparently the way to do it is just mess with how much timing the engine uses to try to correct idle. So it massively undershoots, then overshoots, then undershoots, then overshoots. So timing is going from 5deg to 45deg to 5 deg to 45deg. But I kinda prefer the car to not lurch around and have a dependable idle. Given it didn't idle for shit and stalled about 7 times on the way home, still yet to drive it for the 2nd time to see if it's fixed.
    • Best chop idle FTW, just add an idle timing hole lol
    • Alright. Many little things have been sorted and the car successfully drove home with an incredibly huge exhaust leak. Unsure if it's simply been awhile, but new heads and cam and intake sound f**kin awesome. It might only be me that notices it though, and it's hard to tell from a 15 minute gauntlet run home and attempting to bleed the radiator. Undertrays on, tools out, road brake pads in, idle un-f***ed, time to do some road tuning. From my commute around town it sounds and drives *really* nice (with a max of like 35% throttle). It'll go to a dyno for a proper before and after once the tune is more roughly dialled in. And @Dose Pipe Sutututu I did learn how to do a proper chop tune at idle. I did indeed even do it, but the car shaking around at idle from the driverr seat made me make it smooth again.. I feared for my engine mounts and clerances to engine bay jank. . After the exhaust is fixed I may mess around with it more. I'm just happy to have it drive around without bucking or stalling which is a WIP.
    • Oh and my rear arms may need some attention too.
