Hey people..
I just want to know.. is it really essenial to have these mods in your car. My friend told me that its really not worth it if you dont rev it up to around 700rpm.
The mods for my car is practically stock, only FMIC. So would a dump/front/hi-flow cat increase car response ? more smoother ride? increase kw by? I just want to know if its worth it.
charlie. Cheerz
https://www.sau.com.au/forums/topic/27703-dump-pipe-front-pipe-cat/
A big dump/front pipe is essencial for letting the very hot turbulent air get away from the turbine.
Cat converters are very restrictive so bigger is better to improve flow.
Revs are only part of the equation, it's total flow that is the deciding factor in the size of exhaust needed. Full exhaust can net you 15rwkws or so if youre lucky
hehe thanx guyz.. i'll get it done asap.
Just went quoting around today. Heard its pretty expensive for dump pipe and front pipe seperately. I guess i have to wait for batmbl to get the products done. his one is pretty cheap for dump + front pipe mandrel bend.
Anywhere else in melbourne you guyz would know that does dump pipes/front pipes/hi-flow cats?
thanx
charlie
    • Sane enough. Remove the roof liner, because the acid will go everywhere.
    • Thanks guys, I really appreciate the help and experienced opinions.  I have spent a lot of my life working on boats so I'm pretty good with fibreglass. I'll take everybody's advice in here;  I'll cut a little more of the 2nd layer away as it's a bit crunchy rust and also it's sitting high now. Then I'll wire brush it all a bit to get off anything loose, then I'll soak the bejesus out of it all in rust converter. I'll make sure to get a little hose piece and feed it into all the holes and gaps between the roof layers. Then I'll fibreglass up the holes.  Then I'll get a pallet of filler and mix it with 3 buckets of hardener and hope that is enough to build up the roof corner.  Does that sound sane? Is one type of filler better than others for this?
    • My goals for it atm are to get it registered, respray and some mild power gains eventually... I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
