Hi everyone,
My parents had recently bought a stagea m35 ar-x. I was originally after an Apexi pod filter but i was unable to find one for that particular model. Would anyone know if they are they same fittings as the older model stageas or r34? Or any highly rated pod filter that anyone would recommend.
any help would be appreciated.
cheers!
https://www.sau.com.au/forums/topic/277080-which-pod-goes-into-a-m35/
i believe they are different to C34 intakes.
the V35 kits apparently dont fit either, but considering they use the same airbox setup, i dont see how they would. but its a risk.
there ARE M35 kits, but if youre buying from japan, be aware you MUST have one for an NM35 VQ25DET. or just put a panel in the stock airbox like most of us have anyway
Hi everyone,
cheers!
Yes, the Blitz LM and SUS Power pods both come in a kit for the NM35.
Don't think that they offer the greatest filtration though.
Try to find a place that stocks 3A Racing pods, much better than Apexi and about a third of the price.
If you find a store that stocks them, get them to fit it :laugh:
Same airbox, different intake piping (obv).
but remember the pod sits where the airbox would (seeing as its removed) so i dunno why a V35/PM35 one wont fit if they run the same airbox.
anyway, nothing is better than an apexi pod :laugh:
For the same reason that lovely Mishimoto radiator did not fit in my M35, bit fits straight into a G35/V35...
"anyway, nothing is better than an apexi pod :laugh:"
As usual, I enjoy your sarcasm, Iain!
thanks for that. ill see how i go about sourcing out a 3A Racing one. has anyone here have one on and would you need an adapter as well?
cheers!
Don't have one on (if I ever get around to my custom airbox I will though - so many things to do...), but here are the dimensions;
Width: 160mm
Height: 130mm
Neck: 77mm
The neck goes onto the pipe, so I guess if the measurement fits, it should* fit straight on your AFM if you take the adaptor plate off.
Alternatively, you could have an adaptor plate made up to fit?
OR you could just put a good quality panel filter in.
I've got a Blitz SUS Power Kit but havent put it in yet. It's still new in the box and I might be selling it as the car "might" be going.
From past experience, I've had no issues with the SUS Power filter. I used this on a 350Z and going on the track a few times (and going off into the dirt), the filter has worked pretty well and found no issues with any dirt going beyond the filter itself. What I did notice was dirty it was in a short period of time so had to clean it by blowing compressed air from the inside out.
They certainly are nice piece of kit.
Stainless Steel mesh, so no need to replace.
Can you post pics of the kit?
It is just the pod and the adaptor plate for attaching to the AFM, yes?
I paid about 70 bucks for a k&n panel filter, tho i have the power duct too.. probably the safest one to use i guess. f**k pods and other filters. hks ones cause loads of trouble for my precious front compressor wheel
  • 3 weeks later...
Which panel filter from K&N fits the M35? There are a shitload of them and I can't find one listed for the M35 or V35 anywhere (I read somewhere the V35 has the same airbox).
Don't want to get the wrong one.
if its to fit in the standard airbox, then yes the V35 airbox is the same. AFAIK the Z33 may also take the same filter. come to think of it, its a fairly standard size and i bet you about 50% of japanese made cars will take it. when i put my blitz in, the back of the box listed probably over 100 car makes and models that it suited.......
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
