In heaps of mags and sites I see cars with rays te37's on them some have big dish and some dont, regardless of their offset?? im confused, can anyone explain? below are the two examples of what im talking about... the purple R34 has the dish wheels and the s14 does not... forgive me if this is a stupid question...which im sure it is...
https://www.sau.com.au/forums/topic/277089-different-types-of-te37s/
it's a combination of all of the above, diamter, width and offset and what they call 'face' too. they make different wheels for different models and change the curve of the spokes and how the spoke meets the rim to get the look they want.
did you read my post? like I said it's a combination of things. they can make them look however they want. and offset has nothing to do with the curve of the spoke. offset is the position of the rim over the centre of the hub. so the spokes could attach to the bloody inside of the rim if you wanted and you could have giant dish and still have a 'tough' offset of say +12. or you could have the spokes attached to the outside of the rim and have an offset of +45. maybe learn a little about how wheels are made and measured using good or wiki or whatever and you will understand.
i though a had a good grasp on wheels but obviously there is a shitload of variations...
explain this then, these te37's seem to have little concavity indicating a 'weak' offset but still have huge dish...
They dont actually look like Rays wheels rather Ravs wheels-I may be wrong but they aren't true Rays Engineering Volk Te37 wheels
No they're legit, but as said difference is they're 19's on the R34 & 18's on the S15.
If they were rav's they'd be 19x7.5" & flat...
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
    • I definitely do recommend having a fab/grinding/dirty shed or area to keep all that grinding dust out of your main shed.  But you're right, it doesn't matter how much room you have you still end up filling it! I might even do a short video which will make it easier to fully take in the horrors of what I've created...
