In heaps of mags and sites I see cars with rays te37's on them some have big dish and some dont, regardless of their offset?? im confused, can anyone explain? below are the two examples of what im talking about... the purple R34 has the dish wheels and the s14 does not... forgive me if this is a stupid question...which im sure it is...
https://www.sau.com.au/forums/topic/277089-different-types-of-te37s/
it's a combination of all of the above, diamter, width and offset and what they call 'face' too. they make different wheels for different models and change the curve of the spokes and how the spoke meets the rim to get the look they want.
did you read my post? like I said it's a combination of things. they can make them look however they want. and offset has nothing to do with the curve of the spoke. offset is the position of the rim over the centre of the hub. so the spokes could attach to the bloody inside of the rim if you wanted and you could have giant dish and still have a 'tough' offset of say +12. or you could have the spokes attached to the outside of the rim and have an offset of +45. maybe learn a little about how wheels are made and measured using good or wiki or whatever and you will understand.
i though a had a good grasp on wheels but obviously there is a shitload of variations...
explain this then, these te37's seem to have little concavity indicating a 'weak' offset but still have huge dish...
They dont actually look like Rays wheels rather Ravs wheels-I may be wrong but they aren't true Rays Engineering Volk Te37 wheels
No they're legit, but as said difference is they're 19's on the R34 & 18's on the S15.
If they were rav's they'd be 19x7.5" & flat...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
