id like to know what would the best oil pressure 2 run in a say 9500rpm engine. I know it goes on tolerances but my mate has bought a nitto pump, threw it on and had 120 psi at 8k, this 2 me is 2 high, hes even blown the rear seal out as a result.
Is 75 80 psi up top efficent enough?
https://www.sau.com.au/forums/topic/277127-rb26-oil-pressures/
  • 1 month later...
The rear seal does not see oil pressure. I would not be concerned with the level you mentioned on a cold engine. Oil pressure is your friend.
