Ok,
Don't laugh! But I've used MS Paint to render the following 2 pics on my sedan.
I am after 19" rims and have rendered:
Immitation M3 rims, which need to be redrilled to 5 x114.3 by the tyre shop.....
Or pay an arm + leg for the Work Schwert SC2 rims...
If i opt for the M3s, they are a fifth of the price = I can buy them now...Or wait until next year to buy those Works ones...
Comments?
Edited by siu_loong_bao
I may not be very experienced in this department, but why dont you look into a more VIP type rims? (sorry i dont know any names)...actually look into the older AMG rims and WALD rims aswell i think it would suite the sedan the best...
Out of those two i guess it would be the M3(if your redrilling, look at a M6 wheel, its a sweet a$$ wheel), the works ones just dont look THAT good....btw re-drilling?..how will that work + is it safe??
Personally I like the Work SC2 rims out of the two choices. I think xscape237 is getting a Coupe with SC2 20's on it. I thought they looked pretty good.
+1 on the drilling, how does it work? Doesn't the rim lose some strength?
Hey N15m0
Your car looks great, I have the dark blue.
Are you happy with the fit and drive? How far out is your speedo? What size and offset did you choose?
Regards
Andrew
Thanks. Fit and drive is great, can't feel much difference to my previous 18s. Speedo is not out. 19x8.5 +43 F; 19x9.5 +38 R. Front offset could have been better but beggars can't be choosers :huh:
245/40/19 fronts and 275/35/19 rears
So if u could have chosen, you would have went for a smaller + number, say +35F and +35R? Or even less? I can't make up my mind to what I want at the moment with regards to rim width, offsets, and tyre thickness...
And, looking at your car, 19s don't seem to be 'big' enough for my liking, or maybe it's just the tyres?
There's a special at the moment for the WORK Schwert rims, $2800 USD shipped + any taxes due from a supplier in Hong Kong...Details are:
19x9 +25 Front
19x10 +25 Rear
I don't know, it's all so 'confusing'....
19x9 +25 Front
19x10 +25 Rear
You will definately have problems fitting those widths and offsets quoted above unless you are prepared to dump the car, run excessive camber and skinny tires.
19s on a V are probably the optimum size. Mine doesn't look THT big because I am not dumped. The lower you go, the bigger the wheel looks. Type of wheel also asscentuates the size. A wheel with a lip/dish appears smaller than one that does not. My rears are already sticking out by bout 10mm but I have rolled my inner guards. Fronts I could have gone an additional 10-15mm. I could write a whole book on this but in the meantime, have a look at the attached chart for guidance.
Thanks N15m0 (and mosoto)
Some great information, by that chart your rears should be sitting well outside your guards!
No worries. The chart is pretty conservative and does not take into account rolling guards, and lowering the car which produces natural camber. The limits can be pushed with the right setup :)
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
