Ok,
Don't laugh! But I've used MS Paint to render the following 2 pics on my sedan.
I am after 19" rims and have rendered:
Immitation M3 rims, which need to be redrilled to 5 x114.3 by the tyre shop.....
Or pay an arm + leg for the Work Schwert SC2 rims...
If i opt for the M3s, they are a fifth of the price = I can buy them now...Or wait until next year to buy those Works ones...
Comments?
Edited by siu_loong_bao
I may not be very experienced in this department, but why dont you look into a more VIP type rims? (sorry i dont know any names)...actually look into the older AMG rims and WALD rims aswell i think it would suite the sedan the best...
Out of those two i guess it would be the M3(if your redrilling, look at a M6 wheel, its a sweet a$$ wheel), the works ones just dont look THAT good....btw re-drilling?..how will that work + is it safe??
Personally I like the Work SC2 rims out of the two choices. I think xscape237 is getting a Coupe with SC2 20's on it. I thought they looked pretty good.
+1 on the drilling, how does it work? Doesn't the rim lose some strength?
Hey N15m0
Your car looks great, I have the dark blue.
Are you happy with the fit and drive? How far out is your speedo? What size and offset did you choose?
Regards
Andrew
Thanks. Fit and drive is great, can't feel much difference to my previous 18s. Speedo is not out. 19x8.5 +43 F; 19x9.5 +38 R. Front offset could have been better but beggars can't be choosers :huh:
245/40/19 fronts and 275/35/19 rears
So if u could have chosen, you would have went for a smaller + number, say +35F and +35R? Or even less? I can't make up my mind to what I want at the moment with regards to rim width, offsets, and tyre thickness...
And, looking at your car, 19s don't seem to be 'big' enough for my liking, or maybe it's just the tyres?
There's a special at the moment for the WORK Schwert rims, $2800 USD shipped + any taxes due from a supplier in Hong Kong...Details are:
19x9 +25 Front
19x10 +25 Rear
I don't know, it's all so 'confusing'....
19x9 +25 Front
19x10 +25 Rear
You will definately have problems fitting those widths and offsets quoted above unless you are prepared to dump the car, run excessive camber and skinny tires.
19s on a V are probably the optimum size. Mine doesn't look THT big because I am not dumped. The lower you go, the bigger the wheel looks. Type of wheel also asscentuates the size. A wheel with a lip/dish appears smaller than one that does not. My rears are already sticking out by bout 10mm but I have rolled my inner guards. Fronts I could have gone an additional 10-15mm. I could write a whole book on this but in the meantime, have a look at the attached chart for guidance.
Thanks N15m0 (and mosoto)
Some great information, by that chart your rears should be sitting well outside your guards!
No worries. The chart is pretty conservative and does not take into account rolling guards, and lowering the car which produces natural camber. The limits can be pushed with the right setup :)
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
