  • Replies 51
Im running 4 degrees of caster so hope that isn't to much. If i need to grind a little off i can do that no prob :)
I was looking at these. Looks like a good deal as long as they ship to the USA
Last time i sent a pair of swaybars to the US the air freight cost was over $A400, door to door. So you would be better of buying a pair from the Whiteline US agent or your local outlet. There are now 50 or so outlets in the US for Whiteline.
http://www.whiteline.com.au/dealer_REGION....scription=North America&type=state&region=
Cheers
Gary
When GTR's have a fair amount of caster that can be a problem, pulls the wheel forward and obviously the drive shafts go wth them.
I've got the adjustable bushes, but even with them i'm only around factory, 3.5 degs.
  • 3 months later...
  • 1 year later...
yeah cusco are good. best i've used are ARC though. still got an ARC set on my car and they come with the adjustable rose jointed links too. but the cost man! my god the cost!!!
bang for buck I'd say cusco are the best option and that goes for a lot of their suspension gear. it's not top of the tree but on price v quality it ranks highly in my book. adjustable or not is not that big a deal. unless you are super serious and want to change balance for wet set-up etc. mostly people get a good balance and leave it at that. car will be driveable on most tracks in most conditions with a good basic set-up and can be tweaked slightly with damper adjustment if you have it or swaybar adjustment if you really want to.
I'm getting serious about replacing my standard sway-bars .. is there such a thing as not enough body roll?
The car will be used for hillclimb / mountain / touge runs, pretty much a "targa" car. I have just purchased some Apexi N1 Evolution Pro Spec Coilovers for my 32 GTR .. i believe the spring rates are 11 F and 9 R (according to some website). It's either cusco or whiteline for me, money difference between these two is not an issue.
People talk about adjustable sway-bars in terms of being able to "dial" in the amount of understeer / oversteer .. i presume however that cusco have their swaybars made and sold at the appropriate thickness that will give neutral cornering? Am i going to be disappointed if i get the fixed cusco over the adjustable whitelines? I wouldn't be adjusting the swaybars after i've found the most neutral adjustment.
Thanks for any help :)
The problem you will have is that the spring rates from Apexi are so high that neither the Cusco nor the Whiteline offerings will be anything close to matching the stiffness of the springs. Rolls tiffness is a combination of spring rate & anti roll bar rate after all.
Also the balance can be changed by camber settigns, spring rates, roll centres (read ride heights). So there is no one right option.
For what it is worth I use a Cusco rear and a Whiteline front.
So i should choose my sway bars based on my spring rate? The higher the spring rate the stiffer the sway bar's i should run? Why is that so? Is that so the sway-bars don't become redundant as the coilovers will not compress and soak up the roll? or vice versa?
Cusco rear and whiteline front .. to bias your car more towards oversteer? :)
Yes. Otherwise your car will be stiff in bump settings but relatively soft in roll. Which is not a very nice combination because it wont absorb road undulations very well nor probably corner as well as it could.
Exactly. Although I would term it more so as less understeer.
And wait does that mean that i've bought the wrong coilovers?? What spring rates should i be chasing ? (it's not a daily driver :P )
Not necessarilly as spring rates can be a bit of a personal preference thing. But I would say that they are pretty stiff in the overall scheme of things. For what it is worth mine are about half what the Apexi rates are. It does depend on alot of other things, however.
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
