hey all,
currently trying to get my power fc tuned and the tuner has advised me that my power fc for r34gtt has a version (same as other pfc's afm's n all) which does not interface with his datalogit or software.(he has tuned other r34gtt's but diff version pfc)
now has anybody had this issue before??? if so how did they overcome it?
he has contacted apexi...but god knows when they will reply with a fix.
cheers, Bass
hey all,
cheers, Bass
Weird.. send me a PM, bring your car over and I will connect my datalogit to it to test it if you like.
i wouldn't bother contacting apexi. why would they care if their ecu doesn't work with a non supported, 3rd party application?!?!
if anyone he should be contacting datalogit.
contact fcdatalogit in nz.....
by clicking here
and they will send a patch for the software to your tuner... all gtst/gtt are the same so it should be fine...
also it it his laptop or yours? the problem could also be the usb-serial converter software :rofl:
its his laptop...yeh dont know why its doing that to be honest....its doing my head in.
never read or heard of it either...
guilt_toy im located in sydney...where are you?
he says its not often that it happened and all...i will email datalogit and see where it can go.
is this version thing really that criitical!!
I had this issue pop up once before. The tuner could connect a R33 but the version he had wouldn't connect to my R34. He ended up doing the tune on the hand controller then the next time I had it retuned after a IC install he had the update and it connected fine.
welll see thats what he is planning to do...he is going to tune on his own powr fc (he owns a r34 gtt) and then save the map and re-write through the handcontroller.
he has began tuning...so we will see how it goes.
ive contacted datalogit...and am awaiting a reply for the update.
til then any help would be great.
thanks again.
Epping Sydney.
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
