its not a constant all wheel drive on the R33 GTS4, correct me if im wrong tho im sure ive read it only kicks in once the front wheels start to loose traction then it distributes the weight around.
so it shouldn't be constant??
why do you want to stop power going to the front? burnouts before a drag race? drifting?
using an attessa conroler and running the car in 100% rear drive can damage the clutch packs if used for long periods, or under heavy load
there are plenty of topics on this, do a search to find out more.
have a read of this, its about stageas but its essentially the same attessa system as in your GTS4, lots of good info from guys who have actually messed around with the system
http://www.skylinesaustralia.com/forums/Ru....html&st=20
I have one,
the 33 GTS4's always have a constant 5%ish worth of power going to the front, then if the sensors note that there is wheel spin or the g forces are extreme, ie going around a corner real quick. it will send the appropriate amount of power to the front to regain traction.
the torque controllers dont stop the power to the front (unless its a 32 with the fuse system) all you can do is choose to have it at 0 = 5% front or 1-10 or whatever it is = 50/50% thats all...
that being said, they are VERY handy in the wet when you have some power in the wheels and need to control it.
All the controller does is tricks the attesa system that the car is slipping and how high u turn the dial is how much the controller bullsh*ts you are loosing traction.
The steering wheel goes tight when u turn it up and with some good rubber on the wheels you really notice a good difference.
Adam
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
