Hey guys I was wondering if you can help me out. I am in the process of finishing my engine off. I just put in a 25/30 and im connecting everything back up and getting it ready for its first start. HOWEVER. There is a nice thick black wire with a yellow stripe (just underneath all the wiring near the washer bottle) and I am wondering what exactly it does and where I need to connect it to. Im guessing it is the earth for the block but I'm not 100% sure and also not 100% sure about where exactly to put it. I have also just put in a Microtech LT12S.....(bag it out if you wish but its what I was recommended due to the tuners in Townsville....)..anyways. I have just put the ECU in and when I went to set the injector correction the hand controller didnt come on. So I had a look down at the ecu and it appears to have nooooooooooo power. Could this be from the mysterious black wire which I have no idea where it goes? All help is appreciated :rofl:
Cheers :D
https://www.sau.com.au/forums/topic/277236-ecu-has-no-power/
Hey man, you are correct. The yellow and black wire is an earth strap and it bolts to the right of the engine mount. (not really important where you mount it as long as it is a good earth point on the block).
I dont however think this is your problem as the ECU would still get power regardless. Check over all your wiring into the Microtech and use a test light to make sure the ECU is getting power into all the pins it is supposed to.
Cheers guys I have today off so I will go work on the car some more and connect up that lead. If still no power I think I will just check the ecu harness. If anyone would know off the top of their head.......is the pin number for the main battery power supply to the ecu pin number 58?
Cheers
Ok I went and got a fuse box translation and pulled out the Engine Control 10A fuse to see if it was blown. Yes it was blown. I figured I could have accidently done something so I put the 10A fuse from the hazard lights in there. I connected the battery back up and turned the key. The hand controller for the ECUs screen light up and immediately turned off again. Disconnected the battery to check the fuse I just put in and it was f**ked too :( . OH O. Is the ECU drawing too much power or do I have a nice short circuit happening somewhere?
Cheers
Ok that problem is all fix now :banana: I just disconnected everything under the bonnet one thing at a time till it stopped blowing fuses. It was the connector for the igniter. I just took it off and pluged it in again and it seemed fine. Weird issue. Im on the clutch problems now. But thats for another thread. Thanks guys ;)
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
