Hey guys I was wondering if you can help me out. I am in the process of finishing my engine off. I just put in a 25/30 and im connecting everything back up and getting it ready for its first start. HOWEVER. There is a nice thick black wire with a yellow stripe (just underneath all the wiring near the washer bottle) and I am wondering what exactly it does and where I need to connect it to. Im guessing it is the earth for the block but I'm not 100% sure and also not 100% sure about where exactly to put it. I have also just put in a Microtech LT12S.....(bag it out if you wish but its what I was recommended due to the tuners in Townsville....)..anyways. I have just put the ECU in and when I went to set the injector correction the hand controller didnt come on. So I had a look down at the ecu and it appears to have nooooooooooo power. Could this be from the mysterious black wire which I have no idea where it goes? All help is appreciated :rofl:
Cheers :D
https://www.sau.com.au/forums/topic/277236-ecu-has-no-power/
Hey man, you are correct. The yellow and black wire is an earth strap and it bolts to the right of the engine mount. (not really important where you mount it as long as it is a good earth point on the block).
I dont however think this is your problem as the ECU would still get power regardless. Check over all your wiring into the Microtech and use a test light to make sure the ECU is getting power into all the pins it is supposed to.
Cheers guys I have today off so I will go work on the car some more and connect up that lead. If still no power I think I will just check the ecu harness. If anyone would know off the top of their head.......is the pin number for the main battery power supply to the ecu pin number 58?
Cheers
Ok I went and got a fuse box translation and pulled out the Engine Control 10A fuse to see if it was blown. Yes it was blown. I figured I could have accidently done something so I put the 10A fuse from the hazard lights in there. I connected the battery back up and turned the key. The hand controller for the ECUs screen light up and immediately turned off again. Disconnected the battery to check the fuse I just put in and it was f**ked too :( . OH O. Is the ECU drawing too much power or do I have a nice short circuit happening somewhere?
Cheers
Ok that problem is all fix now :banana: I just disconnected everything under the bonnet one thing at a time till it stopped blowing fuses. It was the connector for the igniter. I just took it off and pluged it in again and it seemed fine. Weird issue. Im on the clutch problems now. But thats for another thread. Thanks guys ;)
    • me too wasnt real happy and cost me a penny or 2 to replace
    • But there's the archetype for the name plate! Here's my view on that stupid TÜV ruleset. Buy a brand name aftermarket piece of equipment. In this case, the Mines front pipe we're talking about. Get it TÜV certified on the car. Damage the underside of it, say on a speed bump. Cut out the damaged section, replace with fresh metal. (For the sake of the argument only), continue doing that to the whole pipe until it is all gone, replaced with new metal. Is this grandfather's axe still the same front pipe? The design hasn't changed (much). The pipe walls are in the same places. The flanges are in the same places. It is functionally identical. How does this differ from a pipe that is ever so slightly different in fabrication (ie the number of welds in it, a few mm here and there in terms of where the pipes run, are joined, etc)? Anyone with 0.5% of a brain can see that there is absolutely no way that the performance (power, environmental aspects, noise, etc etc) of it can be any different than the genuine Mines pipe. Maybe even Mines made 2 versions of this design, with the same differences. How would anyone (say a TÜV inspector) ever be able to differentiate between them? And yet, they are so bloody anally retentive about this stuff. Mad. How upset would they be if you had the wrong spring washers on the flanges?
    • Sakura (cherry blossom) tree at the end of a path going through Kabutoyama Park in Nishinomiya, Japan. Taken with Sharp Aquos R8
    • After a fairly extensive search using Japanese terms and checking Minkara etc, I couldn't find anything even close to your front pipe in the photos. I'm no expert but the two pipes merge really close to the flange connected to the catalytic converter which is rather unique from what I've seen, which makes me think it's more than likely a custom front pipe. The welds and 'more pipe sections than usual for a brand name pipe' makes it seem like a custom one.  Here's some photos of an old Mine's front pipe. You can see that it's just 4 pipe sections as opposed to 6, and arguably looks more like a 'production' front pipe:
    • Wtb r33 low side s2 ac line
