Hi Fellas,
To get the best flow, I was thinking of removing the centre muffler (pretty much having a straight through pipe, no cat, no mufflers, with only a cannon muffler on the end).
However, I am a little cautious of how it may sound.... Has anyone done this?
Does it drone, is it high pitched, deeper sounding etc?
Any help would be great.
Cheers
Edited by Turbz RB-25
I have 3" from the turbo down to a 3" decat, then 3.5" through to a bigg ass cannon. No mufflers nothing just the cannon. from the cat back its a JJR Hyperflow and decat and dump/front are my own. All stainless, all 304 grade as far as I know and decat is 316 grade
thats after a 3540r(.82), and thats on a XTR top-mount stainless manifold.
hell rasinging note, sounds really unique, my tuner mentioned how free flowing the setup was. But it IS insanely loud. doesnt have a doughey wishy washey note like some big diamtre systems you hear. sounds crisp and raspy, and performance wise its great.
can't say I've had any run-ins with the law about the Db level, but I live in a very small city and keep and pretty low profile lol. NOT recomended for built up area's!
cheers
cheers
Thanks mate.
You don't by any chance have any sound or video clips on you tube?
Hey turbz,my exhaust that i just replaced on my R33 was like that.Sound awesome while giving a bootfull but for driving around normally it would get a little loud and irritating.A little bit drony on highway when accelerating a little in 5th.Having said that i actually miss the tough sound she used to put out!I put on a 3 inch kakimoto exhaust and she is a little too quiet now.It almost sound stock unless your hammering it.Would love to have something in between the two.But if your not carrying two kids in the back like i am and in your mid thirties you will probably love it.Have fun man.
cheers
Thats the exact system that i had
i have 3.5 inch from the gutted cat back with just the rear cannon
sounds soooooo nice
but i dont drive it every day but its way too loud if i did
up to you
if its a daily, not a good idea as it will drive you insane
weekend car go for it
Awesome thanks for the comments guys.
I got a silencer when I bought my cannon, so when I am going to the coast, I can just smack that baby on.
SO the verdict is, loud, higher pitched, and raspy note?
Yes except under 3000 rpm
ive got 3 inch split dump ---> 3 inch high flow cat ---> trust peII with the mid muffler removed.
when i first got the car i was sooo over the noise it made, pretty loud compared to my last 33 with oval muffler and mid muffler
now im used to it it doesnt bother me at all. sounds a tad droney at times (could be to do with the auto though)
get alot of people say how they love the sound of my car though. sounds great when you give it a bit
slightly more like this, not like the 3000GT doesn't sound like it at all
that's not my car btw, some random on you tube
might as well get a screamer pipe and make it sound like:
interesting results.
i have a fujitsibu 3'' system mated to a gt3582 turbo, straight zorst to a zetti cannon muffler.
i dont have this ''raspy'' note. I have a nice deep, barbly tone.
Its loud, but bearable.
but as others have said, NOT adviseable for a daily.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
