Ive just bought a Pioneer 600 w amp second hand, two new kicker 6 inch splits and two new blauplunkt 6 inch splits for the rear, one second hand JL audio sub, and ive got a JVC mp3 head unit. Can anyone give me some ideas on weather to run all 4 speakers to the amp or to run the 2 front speakers and the sub ?. Also does anyone know where i could get a general install map (diagram) with wires flowing to each component ?
Thanks for your help !
MATT
https://www.sau.com.au/forums/topic/27733-need-install-help/
do u know the specs of the amp in rms and the specs of ur subs and other speakers?
generally u'd want to run the amp to the front 2 speakers and bridge 2 channels to the subs but normally u'd have a seperate amp for the sub as it requires more power than speakers.
https://www.sau.com.au/forums/topic/27733-need-install-help/#findComment-579851
If you are on a budget, run the fronts of channel say 1 & 2 of the amp. Bridge up channels 3 & 4 by using the outside 2 terminals on the and low pass them. Runn the rears of the jvc headunit, will be all they need. later on, run the rears off that amp as well and go to someting like a mono block for the subs. hope this helps.
Any further questions just shout out
JR
https://www.sau.com.au/forums/topic/27733-need-install-help/#findComment-580019
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
    • Hi Luke, haven't thought about it a lot, trying to get the car into the paint shop first.  Did you want to make an offer? As stated above, I'm just looking for fair market price.
