Ive just bought a Pioneer 600 w amp second hand, two new kicker 6 inch splits and two new blauplunkt 6 inch splits for the rear, one second hand JL audio sub, and ive got a JVC mp3 head unit. Can anyone give me some ideas on weather to run all 4 speakers to the amp or to run the 2 front speakers and the sub ?. Also does anyone know where i could get a general install map (diagram) with wires flowing to each component ?
Thanks for your help !
MATT
https://www.sau.com.au/forums/topic/27733-need-install-help/
do u know the specs of the amp in rms and the specs of ur subs and other speakers?
generally u'd want to run the amp to the front 2 speakers and bridge 2 channels to the subs but normally u'd have a seperate amp for the sub as it requires more power than speakers.
https://www.sau.com.au/forums/topic/27733-need-install-help/#findComment-579851
If you are on a budget, run the fronts of channel say 1 & 2 of the amp. Bridge up channels 3 & 4 by using the outside 2 terminals on the and low pass them. Runn the rears of the jvc headunit, will be all they need. later on, run the rears off that amp as well and go to someting like a mono block for the subs. hope this helps.
Any further questions just shout out
JR
https://www.sau.com.au/forums/topic/27733-need-install-help/#findComment-580019
    • Welcome.  800hp should be a bit of weekend fun!
    • I'm going with "Just run two gates". Fix the problem conclusively. It's the only way you'd ever truly know, right?. This is all pretty much splitting hairs. Even the extreme example where it takes two whole seconds at 100kmh or something sounds monstrously dubious. And anyway, when you're punching the throttle when you 'need' this power, you aren't at 2800rpm in the wrong gear. Test it at 5600rpm in 3rd gear, when you're traction limited punching out of a sweeper. Much difference there when you account for traction?
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
