Hey guys,
We're heading down to Marulan this Saturday to have another go on the best drift track in NSW so far! We will also be dedicating half of the track time to Circuit so both Drifters and Circuit drivers can make the most of the day!
Price will be;
- $110 Project D Drift Club Members
- $130 Non Members
PASSENGERS ARE ALLOWED
- You will need to purchase a 'Passenger Licence' directly from Marulan for $25
- $60 each
- You will need a ADR approved helmet
- You will need to sign on and get a wristband before you will be allowed in the car
To book your spot email [email protected] or call Amy on 0413 614 684
https://www.sau.com.au/forums/topic/277363-marulan-this-weekend-4th-july/
Guys I spoke to Project D and they have agreed to allow SAU members to enter at Project D member prices for this event.
Should be an excerlent day and heaps of track time.
To boot there will be 2 or 3 of Australia's top drifters there as well who can lend a hand to those learning to drift and likewise for those heading out on track for their first circuit event.
I'm dissapointed I can't drive again yet or I would be there for sure!
Hey guys,
Price will be;
- $130 Non Members
- $60 each
Had a great day thanks Amy.
Great to get some drift and grip practise in.
Mid-afternoon i heard a banging sound coming from near the drivers foot area. Turned out the front swaybar had torn off its mounting point to the suspension on the right side of the car - so I had to call it a day early.
Getting it fixed at the moment at Unique.
Cant wait for the next day - it was really fun.
Dani.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
