  • Replies 477
Not sure what turbos the Hi Octane 34 runs but im pretty sure it runs a AWD RB30
yeah its an rb30: http://hioctaneracing.com.au/news_RB30.html
your signature is a crack up & i bet some people really believe this as well HAHA
  • 5 months later...
quick update guys - i decided to upgrade my n1 oil pump to the nitto oil pump as it wasn't up for the task.
greg @ proengines also made a custom collar to better suit the oil pump.
i'll be taking the gtr to crd hopefully this sat for a quick health check :happy:
hi guys,
just did a road test in a back street & recorded the results on my blitz ebc (rob @ rips got me thinking on this):
3rd gear: 1bar boost @ 3800rpm
4th gear: 1bar boost @ 3500rpm
5th gear: didn't have the room but would 'guesstimate' 1bar boost @ 3200rpm
mr rob ward, your t04z setup which makes 1bar boost @ 3000rpm, what gear is this done in?
i should also note that my setup has been tuned for top end power, im sure if i asked jim @ crd to tune for mid range my revs would come down even lower @ 1bar boost...
regards,
marko
i dont think you could beat the stock extrude honed manifolds...especially if they are black coated.
Yo dirty man, do you think it's worth the extra money for a set of aftermarket low mount manifolds- compared to a set of honed and ported N1 manifolds?
I'd like to keep the N1's (I have them all done allready) but if there are reasonable gains to be had I'll ditch them... I don't want the ex-mani's to be the restriction.
I know you were running aftermarket manifolds with the GT-RS's.
2.8, head, cams, greddy plenum and 50mm tb's, GT-RS's....
Cheers
Justin
There needs to be a 2.8 section...
i think i can answer on pauls behalf as ive had this coversation with him in the past...stock manifolds are much more reliable & just as good if not better than aftermarket items.
mark with his hi octane gtr was using tomei manifolds then went back to stock ones which were matched & honed for better response, as per his interview on ignition dvd
Thanks marko.
Yeah, I'm really trying to stick with cast manifolds. I'd hate to have to change manifolds after a few thousand km's because one cracked... unfun job.
I've run 400rwkw with stock-stock manifolds in the past... un ported, honed or coated.
I seem to ask Paulie alot of qn's because he's run good numbers with GT-RS's... I'll be running GT-RS's on the new stroker motor.
Anywho... thanks for the reply.
Cheers
Justin
Cheers
Justin
No...spend it somewhere else
  • 1 month later...
hi guys,
i have ordered a new set of splitfire coilpacks as my factory coilpacks started to misfire. tell tale sign was that 1 of plugs was very dark (thanks for the guidancec paul).
whilst im doing this i looked at my plugs...i am currently running ngk pfr7a (1.1 gap) & have done 1000km with them. should i just clean them (with petrol & toothbrush) or should i replace them as they did clean up well.
my tuner recommended i go with pfr7b platinum if i update them - the problem is that nobody in sydney stocks 7b's let alone 7a's! this is head fark & a 1/2 :D why is it sooo hard to buy a set of plugs???
hi guys,
bcpr7es marko...made better spark and more power with these puppies than any platinum plug you care to name. I run coppers in the race car too...but not 7's.
invest in other mods such as alcohol
Baah... Alcohol is for drinking
Gasoline is for washing parts and
Nitro is for racing!!! ha ha ha
Yeah, I was thinking about methanol a while ago, but it really dosn't go with my street car build. Also E85 isn't available in Tas, so I stuck with the ID1000's instead of the ID2000's...
Oki doki paul. Better spending $20 on a set rather than $150, its a win win solution
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
