  • Replies 477
i missed out 'fit' now ive re-read it.
RB20 ones go on, so why wouldnt RB25 go on? the top of the cylinder head is the same shape?
so why wouldnt the RB25 fit on a 26, if cams were the issue i wouldnt think the 20 covers would fit.
although, the backing plates and gear covers are different shape
Edited by jangles
  • 1 month later...
Hi All,
Quick update:
I recently sold my rb2630 engine to a mate of mine who is setting up an R32GTR circuit car (that engine belongs on the track TBH, too angry for the street).
As soon as he sets it up, I’ll report back here with results.
This guy is a demon behind the wheel...used to pull 1:08s around wakefield with a stock gtr running higher boost.
I now have a replacement Bathurst Winner which is piece of history & icon – I bought back my old Australian Delivered R32 GTR :)
yes it is 'uncool' that i sold my engine BUT the timing was well aligned with the purchase of my aust gtr, it was all by coincidence.
it is however 'cool' that i got my old car back though...here are some pics & 1 of an r35gtr on the way back from picking it up on the day:
Nice one Marko!
  • 1 month later...
Hi all,
My rb30dett is now fitted in my mates circuit GTR, this is his 1st outing (reserved driving) & was doing 1:11’s around wakefield. His car still needs sorting around stiff suspension etc. Engine is tuned down to 350awkw on Federal RSR595s on a very cold track. The 280degree cams are too big and power comes in too late for circuit so will swap them out for 264/11mm lift to bring turbos on 1000rpm earlier. With good tyres that will wipe off another 4sec +.
The best time he did with my current gtr was 1:08 on Pirelli full slicks & only 220 awkw! He is a very good driver!
  • 1 year later...
Just incase anyone is interested. This car is now running the same set up with 300awkw and 595rsr. It has done 1:09.8 at Wakefield park. There is may be a second or two left to shave if I get better tires and my brake zone correctly.
But all credit to the engine. The -10's with 260 cams work magic. A little lag under 4000rpm. But she turn into a monster after that.
U have a great engine there Tuan...I spent a lot of time asking many questions to many people which some can attest to here :)
The only mechanical changes to the engine is the smaller cams from 280s to 260s, upgrade ecu from power fc to vipec, lower boost and now tuned by unique autosports.
I know this as I sold that engine to a good friend of mine.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
