  • Replies 477
rob at rips is running an rb26/30 with factory block and crank making over 1350hp in his 7sec car, he is actually trying to break it but he said it just wont, this engine was built about 3yrs ago :laugh: if its good for rips its good for me
paul is right, its a street driven car
a 26 block is better then a rb30 talking about the block here not the crank size but you guys will be seeing alot more rd28 set ups with 3.4 cranks soon enough
What a great idea an RD28 block would be....an extra 40kg over the front axle on the already front heavy GTR, plus the 5 grands worth of block prep needed to make it fit.
As Marko said its a street car and theres nothing wrong with the dirty 30.
We need vids Marko!
We need vids Marko!
lol - i couldnt agree anymore!
re. the vids...it wont be long, i have a new sony handycam hd which i need to put to the test, it has a youtube upload function :angry:
i replotted my 3rd and 4th gear over each other last night and it looks nothing like that...one line is just under the other...ill scan it for you if you like.
clearly both these runs were conducted in the same gear... the dyno operator has just made a mistake and not entered the right gear into the program
you would be ignorant to think otherwise ;)
you would be ignorant to think otherwise :thumbsup:
Mmmmmmmm, not sure about that mate, we've done back to back dyno runs in 4th and 5th gear and got almost identicle power curves, within 3-5whp or so.
Rob
Rob
Remember that we are assuming the power loss (drive train and traction) between the gears are constant with these discussion. Obviously if they read the same at every single vehicle speed, it just means that you lost power in one of the run.
That is completely different to comparing response between a 3rd gear power run with another 4th gear power run.
Or in some case, I've seen people compare 2 different cars.
Why did I get drag into dyno comparison talk in the first place. Dyno is just a tuning tool :whistling:
Edited by 9krpm
the curves will be the same basic shape but when speed is the bottom axis there is no way one of those runs could be in 3rd and one in 4th.... doing the run in different gears moves the curve along the graph. so the lower the gear of course it will make more power at a given km/h. peak power should be the same, but not at the same speed in every gear. otherwise you'd have a gearbox full of the same gears!
BINGO :):);)
glad someone else has a brain !!!
Edited by Cerbera
Apoligies for giving an example with someones name in it...that was maybe a little too much. (mods please edit name out)
Calling my engine a drag engine is like me calling yours one.
Show me an aussie built RB 30 thats so much more outstanding than what ive got. Im building one to see what all the fuss is about and see if it will actually make what ive already got better. I think the big turbo may enjoy a bit more air...so we will see what just changing the bottom end will achieve.
You were off the mark refering to my engine as a drag engine 9K...that was the point...you have no idea what went into it and how it was put together. The focus when building was to make the engine make as much low down grunt (torque) as possible with the GT-RS turbo's. The reason for this is im making zero boost at the startline as i was using a normal Power FC with no anti-lag, two step etc. When the clutch was popped the car had to be right in the meat of its torque curve pulling the car hard off the line. This resulted in the awesome 60' times which was the real secret in getting a car with limited power into the 9's...it was 60'ing faster than Kier's car with less power and more weight (1470kg) and it didn't need an OS Giken 3L to do this. Only Mark Jacobsen has 60'd a GTR on radials faster than what our car has. A high revving RB26 that has a big flat 5000rpm torque curve is what most circuit guys would kill to have.
Thanks
Paul,
What 60' Times were you getting to get into the 9s with that set-up?
I have a quick question about the Garrett turbo range.
Someone said that the GT-RS (GT2871R 52T i.e. -10's) turbos are still too laggy on the a 3 litre. What i was wondering is if anyone has used the smaller of the GT2871R turbos (the 48 trim) on either a 26 or 30.
They are placed in the middle of the GT28RS (-5) and the GT2871R 52T (-10) yet i have not seen anyone using them, it seems when people want a bigger turbo than a -5 they go straight to the -10, when the 48T is also an option.
This is the turbo i'm talking about, obviously it will need a custom compressor housing.
http://www.turbobygarrett.com/turbobygarre...1R_743347_1.htm
Edited by D_Stirls
come to think of it - mark berrys hi octane r32gtr with rb26 was running gcg modified garrett -5s which cracked over 400awkw as shown on the ignition dvd:
im not sure if he is running the same turbine setup on his new rb30 r34gtr:
...maybe somebody like beerbaron would know this as i think he is well versed in the circuit racing scene
Edited by Marko R1
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
