  • Replies 477
Not sure what turbos the Hi Octane 34 runs but im pretty sure it runs a AWD RB30
yeah its an rb30: http://hioctaneracing.com.au/news_RB30.html
your signature is a crack up & i bet some people really believe this as well HAHA
  • 5 months later...
quick update guys - i decided to upgrade my n1 oil pump to the nitto oil pump as it wasn't up for the task.
greg @ proengines also made a custom collar to better suit the oil pump.
i'll be taking the gtr to crd hopefully this sat for a quick health check :happy:
hi guys,
just did a road test in a back street & recorded the results on my blitz ebc (rob @ rips got me thinking on this):
3rd gear: 1bar boost @ 3800rpm
4th gear: 1bar boost @ 3500rpm
5th gear: didn't have the room but would 'guesstimate' 1bar boost @ 3200rpm
mr rob ward, your t04z setup which makes 1bar boost @ 3000rpm, what gear is this done in?
i should also note that my setup has been tuned for top end power, im sure if i asked jim @ crd to tune for mid range my revs would come down even lower @ 1bar boost...
regards,
marko
i dont think you could beat the stock extrude honed manifolds...especially if they are black coated.
Yo dirty man, do you think it's worth the extra money for a set of aftermarket low mount manifolds- compared to a set of honed and ported N1 manifolds?
I'd like to keep the N1's (I have them all done allready) but if there are reasonable gains to be had I'll ditch them... I don't want the ex-mani's to be the restriction.
I know you were running aftermarket manifolds with the GT-RS's.
2.8, head, cams, greddy plenum and 50mm tb's, GT-RS's....
Cheers
Justin
There needs to be a 2.8 section...
i think i can answer on pauls behalf as ive had this coversation with him in the past...stock manifolds are much more reliable & just as good if not better than aftermarket items.
mark with his hi octane gtr was using tomei manifolds then went back to stock ones which were matched & honed for better response, as per his interview on ignition dvd
Thanks marko.
Yeah, I'm really trying to stick with cast manifolds. I'd hate to have to change manifolds after a few thousand km's because one cracked... unfun job.
I've run 400rwkw with stock-stock manifolds in the past... un ported, honed or coated.
I seem to ask Paulie alot of qn's because he's run good numbers with GT-RS's... I'll be running GT-RS's on the new stroker motor.
Anywho... thanks for the reply.
Cheers
Justin
Cheers
Justin
No...spend it somewhere else
  • 1 month later...
hi guys,
i have ordered a new set of splitfire coilpacks as my factory coilpacks started to misfire. tell tale sign was that 1 of plugs was very dark (thanks for the guidancec paul).
whilst im doing this i looked at my plugs...i am currently running ngk pfr7a (1.1 gap) & have done 1000km with them. should i just clean them (with petrol & toothbrush) or should i replace them as they did clean up well.
my tuner recommended i go with pfr7b platinum if i update them - the problem is that nobody in sydney stocks 7b's let alone 7a's! this is head fark & a 1/2 :D why is it sooo hard to buy a set of plugs???
hi guys,
bcpr7es marko...made better spark and more power with these puppies than any platinum plug you care to name. I run coppers in the race car too...but not 7's.
invest in other mods such as alcohol
Baah... Alcohol is for drinking
Gasoline is for washing parts and
Nitro is for racing!!! ha ha ha
Yeah, I was thinking about methanol a while ago, but it really dosn't go with my street car build. Also E85 isn't available in Tas, so I stuck with the ID1000's instead of the ID2000's...
Oki doki paul. Better spending $20 on a set rather than $150, its a win win solution
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
