another success story for proengines:
one of greg's built Subaru engines ran second in the open class @ 1:39.95 at superlap.
he didn't do the final assembly on it but was responsible for all machining, ported the heads etc.. dummy assembled it etc..
  • Replies 477
hi guys,
just a quick note which might help others - i am getting fuel fumes in the car which is only slight & i decided to drop into earls @ silverwater for their opinion...i am running an 044 in tank & 2 external 044's with a surge tank in the boot space.
the fuel hose i am using is rated @ 300psi, however, the only way to get rid of the scent is to run teflon coated fuel hose which earls stock @ $30p/metre
just another mod i need to do to my car :D
i should also add that fuel hose without teflon coating actually permeates through the membrane which makes sense as you can actually smell the fuel on the line itself. earls also explained that i wouldn't get this smell if i ran 91 or 95 ron pump fuel but with 98ron it has some type of chemical which causes this permeation - less ron is out of the question for me!
Edited by Marko R1
fuel smell fixed!
i am using 1 brand of fuel hose for all my fuel system plumbing to/from the surge tank.
my return line (3/8) is another brand which i bought from robbo's as a last minute decision, this hose was permeating throughout the car...i changed this 3/8 hose to the same brand as the rest and wallah!
very happy :P now i can put my 8mth old baby in the back seat :P
check these out lol
being my b'day my wife bought me 'some' gtr apparel & organised a gtr cake - i just wonder what her family really thinks of me with this silly addiction we all have on this forum haha
btw the pink top is for my daughter, not me
  • 4 weeks later...
last night my brother asked me "show me what it does 1st, 2nd & 3rd gear" ...dont have to ask me twice lol
i launched it @ 4krpm & the thing broke out like mad & his response was "you're kidding hahaaa" ...i think he needs to get his gtr back on the road.
i'll get a launch onto youtube & post it here - every time i give it a push it surprises me :D
rb26/30 is a great setup! i could easily afford to go to a t51r spl with the extra capacity & would still be responsive on the street
  • 4 weeks later...
quick update.
i refurbished my brake calipers & i think they look great...i used an epoxy paint which cures like a thick powder coat & withstands up to 1100degrees so they will never crack or peel - they are inspired by another member on the uk forum who also used a nismo stencil but his are yellow.
what do u think :worship:
im also thinking of having my 'twin turbo' pipe modified to run an internal baffle, to prevent light throttle surge.
guys on the gtr uk forum have had HUGE success doing this mod...is there anyone here in aust doing this work or do i need to ship to the uk :worship:
Just find someone who can tig weld with AC. I have a twin turbo pipe sitting on the floor in my room with the same intentions... been there for 6 months! I will do it soon.
Definitely get it done Marko and update if it is a mod worth doing!
I bet i know who you mean with the nismo yellow calipers
On the TT pipe, the UK guys swear by it, so its worth a try. Im doing it for the next motor, if it doesnt work its an easy swap back to the stock pipe (got 2 here)
guys on the gtr uk forum have had HUGE success doing this mod...is there anyone here in aust doing this work or do i need to ship to the uk :D
Eaaaassyyyy tiger. You can have mine if you like. Exactly the same as the UK guys. I wont/cant use mine with my cooler.
will do mate - i will update the thread with the end result...as stevo stated though, plenty of guys from the UK who do say it works!
yeah its your mate with the black gtr :D
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
