my last post was clear as mud, the point i wanted to make is that its like shifting a truck with the low rev limit.
i havent been that gentle with it :) my question is do i raise the boost/rev limit or wait till 1500km?
  • Replies 477
How much head work did you get done by Greg @ proengines...?
I have a 30 built by Greg and just sent a 26 head over for a little upgrade. Will be interested to see how your setup goes.
I will be running a T51 with 1.05 rear and C4 auto.
im running stock valves, 14hrs of porting was done blending bowls, open exhaust ports, spot face for larger lobes, match port manifolds and full service head
if i missed anything im sure greg will correct me
All calm...sorry Shane...buddy cuddle?
Nothing DiRTy about a 30...lol...ive just bought a nice set of Argo's...hehe
Yes Marko...give it some stick!
ok paul, but be gentle :)
Paul, that forklift is a diesel, maybe you should post it in the diesel block thread? :)
At least the Nissan is infront of the Volvo.
Yeah Marko/Greg that would be good, im looking for someone to do headwork for me very soon, my normal guy is tied up for ages. Looking for max flow. I know a mob in S.A. have got some good numbers, but local would be nice
steve, flow figures should only be used as a guide, if u go chasing 'max flow' u'll prolly find the head will be worse than a stocker.
the results u get from a flow bench are only static volumes, i.e flow in cfm is only measured at set lift heights and they dont take into consideration the rapid change of lift variations from an engine running in the real world (valves open/closed thousands of times and varying amounts)
have a look at the thread i posted about a head i had done recently
hey nick - jim wants me to take it to 1500km, he will then raise the rev limit from 5000rpm to probably 8000rpm? he will also raise boost to 13psi & lean out the fuel, as advised.
he then wants me to take it to 5000km then perform the final tune with full boost & dialled cams...jim is being overly cautious which isnt a bad way to operate.
...im not waiting that long, as advised by greg @ proengines, do the 1500km then let it rip - the block was 'tunnel honed' which helps rings bed in.
Add me to the Paul and Rob list. I've posted it up eleventy billion times, run engine for 20 minutes, until it is nice and evenly warmed up to operating termperature and change the oil filter. Then drive to Bathurst, have breakfast with the guys to let the engine cool a bit and then drive back, that's around 450 k's. What I don't see on the list above is the next step which is "check the leak down". That will tell you if the rings are beded in, the bearings were run in by the time you got it out of the driveway. If the leak down test is OK, then drop the mineral oil, change the filter again, fill 'er up with synthetic and off for the final tune. This pussy footing around for thousands of k's achieves nothing.
Cheers
Gary
a. the 1st 300km i ran run-in oil
b. im now running a new filter with mineral oil
c. next change @ 1500km to full synthetic
im doing the bathurst run tomorrow :( with a mate who owns a worked Ford XBGT, nice car rumbles like thunder (harley equivalent on 4 wheels)
rob & paul...am i really that bad with my emails :) u've given me a complex, i feel like a STOONK C*NT
Marko, that was torqe plate honed. As I said, oil change @ 500, one after that and let rip.
I saw a car driving along the shoulder of one of the parkways here doing about 20km/h with RUNNING IN on a big cardboard sign in the back window. sometimes you've got to laugh.
^^ Yep..thats the correct way to break in an engine properly.
All my engines in the past were fired up on the engine dyno...oil temp reached,then start giving it a few pulls under load to 5000rpm..then pull the string and give it everything .
Engines leak down perfectly.
No way would i be pussy footing around for hundreds or thousands of kays.
Start giving it boost & rpm.
Motor initially run with penrite mineral oil ..half a dozen full power pulls made..then oil & filter dumped switched to royal purple 10-40,then back into it with full power runs.
Only way to do it .
And i have seen hundreds of engines dynoed & run this same way..all with the same results.
Edited by ezy_09s
i remember coming across this article a while back when i had my bike - there are a few guys on gixxer.com which swear by this method - it is a good read
told you you'd like the clutch.....
good work Marko
dennis, its drives like a normal clutch, i gave it the wife test and she couldnt believe it as well, after having a triple then twin plate i will never go back. ive been questioning JB clutches and had the opportunity to get 1 two times in the past but i chickened out my mentality was "as if an aust single plate can hold like a jap multi plate"...i should have listened to paul from the onset
it feels like a standard gtr clutch just a bit springier (for lack of a better word) - you would never know its modified.
after looking at it, i think its the way he utilisies the thrust bearing on the clutch fingers as it sits closer to the tip of the fingers on diaphram then what it did on my previous twin plate.
its get more leverage like this & it feels nice with the 4000lbs pressure plate - maybe u should speak to jim berry direct about this, he'll chew both of your ears off :P
definitely do not wait 5000kms to give it the full tune and full boost. the engine will be half worn out by then let alone run in!! lol.
listen to greg. he built the thing. between 1000kms and 5000kms nothing is going to be achieved by running on a rich, conservatively timed, low boost, low rpm tune. except frustrations and boredom!
if you've done 1000kms then it's well and truly ready for the full ponies! :( get the wick turned up and enjoy. :)
how light could it be? The NPC Twin plate we have in the race car is lighter then the single plate in my road car....it shits me, because it shouldnt be like that!
Is that the solid or sprung centre NPC twin plate?
Looking Good Marko!
Where'd you get the silicon hose cooler kit and fuel rail from?
Thanks
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
