OK,
I want to remove the VERY VERY dark tint that came with my new import.
Is there are proper or correct way of doing this ? Or do you just rip it off ? THe last thing I want it getting into a fiddly excersise.
Thanks in advance
https://www.sau.com.au/forums/topic/27741-how-do-you-remove-window-tint/
That's Ms 99 to you, thanks
Whoops, Sorry...... :cheers:
Thanks for the feedback peeps - I'll try on the weekend - I do have one of those Steam Duck thingies..... I might try that and have a hair dryer on standby !
Cheers,
Originally posted by MRK25T
Your using your turbo to remove the tint? :(
He he - it might melt the glass, the glass might turn to carbon, then form into DIAMONDS
And then I'll be rich......
Might have to get a bigger turbo :P
The way I took mine off is to get:
-scraper blades.
-spray bottle with warm water and dish washing liquid mixed.
-Scrape and peel abit off then spray abit and repeat
Have fun,BTW are the demisters on the back window in the glass or on the inside?
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
