  • Replies 147
Posted Images
well i got this list from forzamotosport.net (threse a confirmed cars that have been seen in pictures and video)
Nissan Race Cars (4)
3 YellowHat YMS TOMICA GT-R (2008)
12 Calsonic IMPUL GT-R (2008)
1997 #23 Nismo R390
23 XANAVI NISMO GT-R(2008)
Nissan Road Cars (16)
1970 Nissan/Datsun 510
1969 Nissan Fairlady Z 432
1994 Nissan Fairlady Z (Z32)
2003 Nissan Fairlady Z (Z33)
2010 Nissan 370Z
1998 Nissan R390
1969 Nissan Skyline GT-R
1973 Nissan Skyline GT-R S2000
1993 Nissan Skyline GT-R R32
1997 Nissan Skyline GT-R V-Spec R33
1999 Nissan Skyline GT-R R34
2000 Nissan Silvia S15
2000 Nissan Silvia Top Secret D1-Spec S15
2009 Nissan Versa SL
Mines R32 Skyline
2002 Mines R34 Skyline
Edited by BigDirtyJase
https://www.sau.com.au/forums/topic/277410-forza-3/page/2/#findComment-4844115
The poster instore never mentioned anything about the limited edition.. least not in the store I went to. They were super busy at the time too so I didn't get to ask anyone. I got Forza 2 collectors edition box set from JB HiFi when it came out and iirc it was around $75-$80? much cheaper either way
https://www.sau.com.au/forums/topic/277410-forza-3/page/2/#findComment-4844342
yeah bozodos there is a 250GB HDD coming out for the Xbox360 but it will be in the the Modern Warefare 2 bundle (for the US Kiddies) and rumored on a Forza 3 bundle (for the Euro kiddies)
The MW2 bundle appears to be an elite console with a custom Modern Warefare 2 case, two black controllers, Modern Warfare 2 game and 250GB HDD.
Now I wonder how much the 250GB HDD will cost seperately (knowing microsoft it would cost more than an Xbox360 Arcade console)...if only it was like the PS3 where you could put any Laptop drive in
https://www.sau.com.au/forums/topic/277410-forza-3/page/2/#findComment-4846826
2 downloadable tracks and extra "legends pack". Including an airport runway hangar ect, high speed ring
http://forzamotorsport.net/en-us/ForzaMoto...ay_One_DLC.aspx
’65 Alfa Romeo Giulia Sprint GTA
’64 Aston Martin DB5 Vantage
’81 BMW M1
’60 Chevrolet Corvette
’69 Dodge Charger
’57 Ferrari 250 Testa Rossa
’80 Fiat 131 Abarth
’67 Lamborghini Miura P400
’71 Nissan Skyline 2000 GT-R
’65 Shelby Cobra Daytona Coupe
https://www.sau.com.au/forums/topic/277410-forza-3/page/2/#findComment-4869779
Pre-Purchased my special edition today also :D NFS Shift is looking pretty good too as far as detail n all goes.. haven't played it yet, but for now Forza 3 is next on my list! :D
NFS was pretty shit hey!! too unrealistic of handling. Forza is soo much more realistic!!
https://www.sau.com.au/forums/topic/277410-forza-3/page/2/#findComment-4874552
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
