  • Replies 147
Posted Images
all the top drift scores ive seen have been that setup... i seriously cant drift with the controller... im not even going to attempt setting a score without getting a G25 or 27 first
My Datsun 510 has over 700kw :)
Best i can get out of it though is a 9.8 1/4
I need to learn to tune cars properly cause i know you can squeeze an 8 out of it
The G25/27 doesn't work with the 360 afaik.
https://www.sau.com.au/forums/topic/277410-forza-3/page/8/#findComment-4921016
Yeah I can't get a launch with the controller either, it's damn near impossible...
Even if I tweak the shit out of the suspension setup, tune the gears longer etc I still can't really get a good launch. It just always spins or bogs then spins...
Even the traction control sucks arse!
https://www.sau.com.au/forums/topic/277410-forza-3/page/8/#findComment-4921118
Does anyone know if ATTESA is effected by having 'stability control' off in options? Is the 'stability control' like an extra layer of software control over and above ATTESA, 'yaw control' etc and other mechanisms found in the cars themselves?
/wish the 33 GTST was available. :P
Edited by Tony de Wonderful
https://www.sau.com.au/forums/topic/277410-forza-3/page/8/#findComment-4922175
nooooooooooooo
lucky you told me now... although i could still use it on the PS3 for GT5
the only way to launch in this game is everything off... manual and as soon as you take off change to second. I did that and ended up going from a 9.8 to a 9.5
i still need to find a good tune for it though cause others are getting 8s... low to mid 8s.
thinking about it... the ones in the 8s are probably using wheels and not controllers, maybe it has nothing to do with my tune.
has anyone posted up the links to their store fronts?
I'll do mine when i get home.
https://www.sau.com.au/forums/topic/277410-forza-3/page/8/#findComment-4922229
  • 2 months later...
    • I know it's been YEARS but hunting down that trunk lip spoiler!
    • Absolutely nothing wrong with a Profec or similar. He's on a Nistune, so external boost control is a better option anyway.
    • I would not replace the gauges. A well setup tune should never require any of that. I'm of the opinion that if you can't safely hand over a car to your parents to drive it's not fit for purpose and more engineering work should be done. Honestly I'm not a fan of external boost controller boxes either but if you have to you can shove the controller into the glovebox or something once it's set up. Tee it off the OEM MAP sensor. Also you probably want to put a two pin plug on the new solenoid, bolting it to the OEM location works. Just separate the wastegate line and compressor outlet so it will work on a 3 port solenoid, kevboost was walked through how to do this on an RB26, same idea just different locations on an RB25. You may have to remove the restrictor in the OEM hoses if they're still in there.
    • Yep, it's why in Australia we never brought in the 1 child policy like China.  China can't afford to use the shit they make in their own country as it's too much to risk having only one child...  Or maybe that's how they test their shit before they send it to Australia - they use the second kid that families had when they weren't supposed to as the tester?  They weren't supposed to exist in the first place so no loss if they succumb to a work place incident?  🤣
    • It's also the reason neither Duncan or I can own a car rotisserie
