I have a full set of for Rays Gram Light 57F Pro for sale.
Colour: Noble Gold with Titanium Lip
Size: 18x10 + 20 Offset Approx:70mm of Dish
Accessories: Comes with no tyres or centre caps. Two Rays valve caps are missing, stolen buy punk kids.
Condition: There is no gutter rash on any of them, one rim has a small dint from when i bought them got damaged in the post (really ticked off about), which is barely visable when tyre is on. The other has a small scratch from a stone chip, but otherwise in very good condition.
They look very nice, great for a show car, tires are still on them but can be removed straight away. The wheels where always washed with rain water and kept clean. Selling because they are too beautiful to use on a track car and need the money to finish off the rest of car. Any buyers are welcome to inspect, will post anywhere at buyers expense.
Contact: Ben on 0423481630 or [email protected]
Price: $3200 cost me well over $4000 special order have done approx 7000km's
hey mate i like your rear bar
is it carbon fibre? whered u pick it up?
Hi
Yeah its a carbon fibre diffuser made by ABFLUG, bolts straight onto standard rear bumper. Bought it off RHD Japan bout 2yrs ago for about $1600, that was when the yen was 107 to the Aussie Dollar, probably over $2000 now.
BUMP $3000
  • 1 year later...
Fit under stock S15 guards without rolling them?
probably not. these are way too wide. a roll will help though but you'll probably need to flare/pump the guard to get em under. do it. will look sexy
(using my brother's login to reply)
Haha I know they will, which is why I am buying a wide body kit and already have a set but without the titanium lip. Although I have been told the front two will never fit under my guards which is why I am selling 2 D:
yeah fitting 10inch rims on the front of a silvia would be very hard considering the offset
  • 9 months later...
Bump
I am putting these up for sale again $3000 with tires they have brand new Rays Centre Caps and Rays Valve Caps, need them gone asap as the car is getting turned into time attack car and i want to buy a set of TE37 SL for track racing. Will post updated pics up later this arvo.
  • 5 months later...
hey man off topic i saw your r32 in performance imports, f**kEN PORN!!!! love ya work fellas. what to have a look myself when i come through mackay might bring my 4door awd r32 in for some fun with ya's.
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
