just recently took off my factory weather shields and there's a 5-7mm gap along the top of the door between door and roof. The rubber seal does not sit flush against the roof. I'm not sure if this is normal or due to the weathershields which used to cover the whole thing.
If someone who has had no weathershields at any point could take a couple of snaps of their roof rubber seals that run along the front doors and post them here that'd be appreciated, cheers
https://www.sau.com.au/forums/topic/277422-need-a-favor/
Pretty sure there is a gap on mine too. i'll try take a photo and post it when i get home from work.
Do you wanna sell the weather shields i could be interested?
https://www.sau.com.au/forums/topic/277422-need-a-favor/#findComment-4691552
they were resisting removal so ended up shattered and in the bin, sorry ... if it's any consolation, they're pretty useless as they were small and look like shit
oh ok no worries, yeh i was undecided if they would look any good or not on the car.
https://www.sau.com.au/forums/topic/277422-need-a-favor/#findComment-4691693
Ok took a couple of photo's but they didnt come out real good. This is the best one.
Looking at em there is a couple of mm gap untill it starts to go down the side of the front window then it pretty much sits flush hope this helps :bunny:
https://www.sau.com.au/forums/topic/277422-need-a-favor/#findComment-4692386
hm I'm gonna have to stop by one of those places that sell skylines on para rd and check them out ... I'm pretty sure it's normal to have a small gap, I just can't see how it would have formed otherwise. On the far side inside the gap you can see where the water supposed to drain ..there's some sort of sponge there.
https://www.sau.com.au/forums/topic/277422-need-a-favor/#findComment-4692547
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
