  • Replies 66
That is so great that there is such a age gap? that appreciate the skyline. I was always under the impression that it was mainly the younger people that where interested in this car. WOW 18 to 50 didn't know it was so broad.
Yep I'm 54 later this month.
So far I've owned
S54
C110
C211
R30
R31
R32
R33
R34
V35
OK I've been a Skyline tragic for 35 odd years before they became trendy
Last few posts have upped the average
Turned "60" in April - still a couple of yrs younger than Jim Richards & still can't see myself driving an auto.
Can't afford an R35 import for a while yet anyhow. :P
So yeh, I was born in the 1st half of last century - just!
For a lark, I've sometimes contemplated walking across the road towards my car holding a white cane & wearing dark sunnies >
Then I'd shock the living daylights out of the onlookers driving a car like this :wub:
Datsun 1600 was my 1st car "new"; then,
Datsun 180B "used"
Ford Escort Van "Pharmacy Van"
Datsun 240K "new"
Alfetta GTV 2l. "new"
Sigma SE "used"
Volvo 245GL "new" to keep the family safe; but still got booked by police in light aircraft over Woodford
Skyline R31 Silhouette "new"
Mazda 929 "used"
Maxima G "used"
Alfa Romeo 164Q "used"
Skyline R33 GT-R (midnight purple)
Honda Prelude 5th Gen "used"
BMW 328Ci "used" + N13 Pulsar (daily)
Skyline R34 GT-R (pearl black) + Prelude 4th Gen (daily)
BTW, for the record, there were 2 guys older than me at the R34 GT-R 10th Anniversary Drive; which made me feel better :P
Datsun 180B "used"
Datsun 240K "new"
Sigma SE "used"
Mazda 929 "used"
Maxima G "used"
I knew you would turn up sooner or later ya old prick. :D
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
