OK.Did the decat pipe experiment.Noticed a little increase in performance.The exhaust note was maybe 5 decibels louder but had an awesome throaty sound when on boost,absolutely loved it.Did notice how noxious the fumes were though,so after 2 days of driving i put the cat back on.I've decided instead of getting rid of the cat i'm going to get rid of the mid muffler.The kakimoto exhaust i have has the big oval muffler at the back and between that and the mid muffler i can hardly hear the exhaust!Cheers for all the input and replies fellas.
yeah mate they don't make much difference in the sound or note but the gain is probably not worth much just do one and use it for track days..
5dB is a MASSIVE amount... Its not like going from 50km/h to 55km/h - its like going from 50km/h to 250km/h
I'd be interested to know how you measured 5dB.
The muffler will cause it to be louder than a CAT removal anyhow
The 5 dB was just a rough estimate.Just say for example it was 5dB, how much louder do you reckon it will be without the mid muffler?Cheers
i run Mines dump pipes, and a aftermarket front pipe, and 3in cat back exhaust with 1 oval muffler, and a Magnaflow 3in cat, its quiet enough not to get noticed by the cops, which is great. and it sounds pretty good at full tilt.
i had a Decat on my WRX and it was a pain with the rear bar getting dirty.
the gains arent much at all with a Decat vs a high flow cat, maybe 5-15kw at the most.
but the worst part is
Cat = LEGAL!!
DeCat = Flames out the exhaust (yes i do admit they look cool), but if the cops see = BIG FINE!!
id rather be on the safe side, cos you cant always not make your car belch a flame when you're being watched.
Brez
Cat = LEGAL!!
Brez
thanks for the reply
i got same exhaust, nice sound. Just cant hear it when ur IN the car. swapping for a new cat back soon
my cat back is f**king loud. once i sell the stagea i will be selling it and getting a custom one made up similar to the one on the stagea using magnaflow mufflers. might just skip the mid muffler on the 32 though and put one of these on the rear http://www.magnaflow.com/02product/shopexd...ain&id=8049
stagea has this http://www.magnaflow.com/02product/shopexd...ain&id=7947 and a mild mid, catco cat and a JJR dump/front. 86db
my cat back is f**king loud. once i sell the stagea i will be selling it and getting a custom one made up similar to the one on the stagea using magnaflow mufflers. might just skip the mid muffler on the 32 though and put one of these on the rear http://www.magnaflow.com/02product/shopexd...ain&id=8050
fixed a link
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
