hey guys got a few things for sale.
1 - stock R32 exhaust should be 2 - 2.5 inch
good for N/A car, will fit 2/4 door has a hole.
asking $100
2 - 4 stud 8mm floating spacers, have no use for it. my cars 5 stud
asking $25
3 - headlight switch for R32 in working condition
asking $35
4 - side mirror control (one that adjusts and folds them in)
was working when removed
asking $25
5 - trust (copy) rear pods to suit R32 2dr, good contition
they dont fit my 4door
asking $80
6 - "powerup" manual boost controller, brand new, blue in colour
asking $30
7 - hicas lock bar, brand new,black in colour
asking $110
8 - binatone X350 GPS, good condition, black in colour
i use my phone as my gps now.
asking $70
9 - momo steering wheel, no horn button.
asking $20
10 - HKB boss kit to suit R32 used but near new condition
asking $50
will consider reasonable offers.
contact via PM
Edited by bert_
https://www.sau.com.au/forums/topic/277462-r32-parts-sydney/
Can't PM cause i'm only new to SAU.
But i'm after a headlight switch. Still for sale??
I'll take it if it is....
Would it be possible to pick up on the weekend??
Cheers,
Alex.
Cheers,
Alex.
yep the headlight switch is still for sale. its the one that you twist, not the high beam and signal.
cheers.
cheers.
Thats the one i need... :P
I'll contact you soon.
Cheers,
Alex
Edited by gurumaster22
hi
do you have a silvertop CAS?
Also willing to meet me half way for the GPS, I live it blacktown so maybe meet at weatherall park or smithfeild?
cheers
elliot
no, the only parts that i have listed are the parts i have available. i can meet you at wetherill park if your genuinely interested in the gps.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
