Hi all, priorities have recently all changed. Recent house purchase and now a little one one the way, means i have to turn a lot of my toys back into coin. This stuff has taken me many years to acquire and items are in excellent condition. No Lowballing please. I will not reply to these. Please PM me if you are interested. There will be a few bits and pieces to be added later, but here is the bulk of it. Parts are in Gold coast and brisbane. Small items can be sent post or picked up. Larger items we can discuss. but all freight to be paid by buyer.
ELECTRICAL
Splitfire Coilpacks Suit RB26 - Used for 3 month $450
Defi gauges - White face (COMPLETE MATCHING SET) 4.5" tacho $350
60mm Water temp $230
60mm oil temp $230
60mm fuel pressure $230
60mm oil pressure $230
60mm boost $200
All with stands, wiring, sensors and control box $1350 for the lot or will seperate.
2 x Nissan AFM's, RB series with green label comes with HKS air filter (green filters) $250 for the pair
FUEL INJECTORS
SARD 1000cc Top Feed Injectors, cleaned and flow tested. These will flow 1200cc at 60psi of fuel pressure!! $800 (brand new these are $280 per injector!)
Apexi 600cc Top Feed Injectors, cleaned and flow tested. $600
TURBOS/MANIFOLDS/WASTEGATES
T04Z Turbo kit includes Garrett T04Z turbo (0.82 split pulse rear V-Band) Turbo comes with feed line and drain. $1500
6Boost high mount split pulse Manifold $700
ENGINES
FORGED RB30/26 4WD!!
RB30 Block – extensively prepped, drilled to suit bigger head studs, bearing caps grooved etc
RB30 Crank
King Bearings – brand new
Spool Rods
CP Pistons with brand new rings
ARP main Stud
Custom RB26 sump adaptor plate with CHROME MOLY main caps
ARP Head Studs RB26 size, block is drilled and tapped to suit
Tomei Metal Head Gasket
Tomei Oil Pump & Collar
R32 GTR Head
Extensive Porting
270/270 10.8mm Lift Tomei Profile camshafts
+1mm Stainless one piece valves on Inlet & Exhaust
BC Valve Springs and Titanium Retainer kit
Painted RB26 Covers with -12 weld-ons
Gates Timing Belt
N1 water pump
Rb26 Sump (larger one can be supplied if needed)
All machining and assembly complete
$13000
STANDARD RB26DETT ENGINE - Comes with the following parts
complete inlet side including plenum, TB's, fuel rail & inj's
Complete set of covers
Cam angle sensor
turbos, manifolds, std dumps
standard flywheel
coilpacks and coilpack loom
$2900
DRIVETRAIN
PPG Straight cut gearset (1st-5th), fully rebuilt and reconditioned with new dog gears, PPG billet selectors, upgraded input shaft (Hollinger Spline). Comes complete with NPC twin plate clutch to suit, bearing carrier and everything required for it to be complete bolt in item. $8500
INTAKE
Hypertune 90mm Plenum and Hypertune Throttle Body $2500
COOLING
GREDDY Alloy Radiator R32 GTR $950
MISC
Safety 21 (pretty sure that is the brand) R32 GTR Half Cage (bolt in) with bolt in side intrusion bars. Bars are 40mm diameter. $750 comes complete with all plates and bolts.
Large Oil Cooler -10 fittings $150
WHEELS AND TYRES
Starcorp Wheels 18x9.5 & 18x8.5" rims only $800
R33 GTR Wheels rims only $900
Koya Racetech 18x9" Wheels (4 X) Black centre, polished lip Fitted with brand new 265/35R18 Federal 595 SS tyres $1000
Koya Racetech 18x8" Wheels (2 X) Black centre, polished lip Fitted with brand new 235/40R18 Federal 595 SS tyres $500
Edited by GTRHOLIC
  • Replies 43
ELECTRICAL
60mm oil temp $230
60mm boost $200
FUEL INJECTORS
ENGINES
RB30 Crank
Spool Rods
ARP main Stud
R32 GTR Head
Extensive Porting
Gates Timing Belt
N1 water pump
$13000
Cam angle sensor
standard flywheel
$2900
DRIVETRAIN
INTAKE
COOLING
MISC
WHEELS AND TYRES
standard engine sold.
can you pls post pics of Starcorp Wheels and will you post to vic at my cost?
will have photos soon. sending down to vic will be approx 130. unless you can organise your own courier.
cheers
Edited by GTRHOLIC
ELECTRICAL
60mm oil temp $230
60mm boost $200
FUEL INJECTORS
ENGINES
RB30 Crank
Spool Rods
ARP main Stud
R32 GTR Head
Extensive Porting
Gates Timing Belt
N1 water pump
$13000
Cam angle sensor
standard flywheel
$2900
DRIVETRAIN
INTAKE
COOLING
MISC
WHEELS AND TYRES
updated list, r33 gtr wheels have been sold. Splitfires and apexi injectors have been sold.
Edited by GTRHOLIC
Hi GTRHolic,
I am interested in your R33 Rims and the Greedy R32 Radiator. Are they still available?
Also where are they located so I can enquire about courier costs?
Edited by StarkReality
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
