Hi guys'n'gals
I have this elusive howling noise that i just can't seem to get rid off... and it seems to be doing funny things.
The main problem is that it doesn't seem to howl on the dyno anymore (where it use to) and you can't tell or it's harder to hear it when on the dyno, as opposed to in the car on the road. This is annoying, as we can't really check something when it's just not there (dyno)
On the street, the howl builds as boost builds and if you really give it some stick, something seems to "give" or "let go" before rev limit. Like a muffled whump, as if perhaps something is blowing off... but doesn't :D Hard to explain. First time it happened, i was thinking "that must be what it sounds like when a cooler hose blows off, etc", but everything is fine and in one piece :huh:
Ok, now the weird thing, one day was at the tuners, a loose hose was spotted, fitted it more tightly, tightened clamp and i went to take a test drive. The difference this time around is that i had removed the front bumper in case we needed to get access to the FMIC. When i took the car for a drive, without the front bumper it did not howl at all :D I'm like sweet, that loose hose must have been it, and we're all good. Get back, chuck the bumper back on, drive home and you guessed it... howl is back.
The front bumper has a fair whack of room around it on the inside, so it doesn't seem to be pushing up against anything,etc but i can't explain why no bumper would make any difference.
The other weird thing is that it won't howl on the dyno anymore, just on the road, which again, doesn't make much sense to me. (It has howled on the dyno before, but was easily audible)
It's near impossible for the tuner to fix because the only want to test/fix it is when it's on the dyno, but it won't howl on the dyno. Can't fix something that's not really there to begin with.
I'm trying to get the car ready for a track day on Saturday, but i'm not taking the car out as is as i'm concerned something might just blow up/off, it's a horrible sound.
Oh, and i've got a stock BOV, but i've noticed when you really give it some stick, and the howl ends up with that muffled "whump", the BOV sounds like a damn chapel st spec HKS, it's like sututututu... :blink: :blink: "sutututu" from a stock BOV?? Was under the impression that is a bad sound for the turbo...
I'll try and get to the tuners tomorrow, but would welcome any thoughts :)
cheers,
daniel
Well I guess when the car's not moving you don't get air travel through the bumper so it won't make any noise. I guess its not some thing to worry about. You should get a proper BOV before hitting the tracks.
Edited by kwickr33
it has howled on the dyno before, and i'm pretty sure it's not just air passing through the bumper because the noise is dependent on your right foot, not speed, if that makes sense. ie, i could cruise at 100km/hr and not hear anything, but put my foot down, wait for boost to build and it will make itself apparent.
that and i'll rack up the 'warnings' on my boost controller when it happens, and get 'peak warnings' when i get that muffled whump sound. Almost certain it's a boost related issue, as opposed to air around the bumper (which has never been an issue until we've started upping the power/boost on the car)
is there a certain level that the stock BOV out lives its usefulness? i thought it was fine for some fairly decent power
i have the same issue. but only because i removed my AFM to my intercooler piping to allow me to get a custom intake made up without the hassles of mounting an afm then filter. Im uncertain what the noise is but it is a slight howling sound, sounds like not enough air flow is making it to the intake or something. hard to explain.
wouldn't know how to check for manifold/gasket leaks
howl can get pretty damn loud and wouldn't have the foggiest about the belts
trying to get the car ready for a track day tomorrow, but just don't want to chance it...
went for a drive with bumper off, howl is there.
Came back, fiddled with and tightened up the pipe the tuner spotted one time (i think it's slowly working it's way loose) went for a drive, seem to have gone.
Bumper back on, went for a drive... doesn't seem like it's there. Let it cool, to come back and check pipe again...
Checked pipe, looks to not have moved... went for a drive, howly mc howl howl again - come back, completely loosen pipe/clamp, shove in, tighten up.
Go for a drive, slightly better but not my boost controller is beeping at me which i guess means something is spiking a bit and my BOV is still thinking it's on chapel st.
so combo of BOV and howl, going to have to skip the track day tomorrow :)
at what power/torque would we be expecting the BOV to give up?
I have had a howling/screaming when on high boost/revs for a while too, have just been fitting some extra goodies around exhaust section & noticed loose bolts on exhaust manifold, maybe worth a check on yours too
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
