slightly off subject but......looking into updating my wife's car.
She wants the following.
*4WD(so we can go 4 wheel driving)
*Diesel
*7 seater....at least
*less than $20,000
So I came up with something for her.....I reckon it's hot.
Edited by Jetwreck
*Diesel
*less than $20,000
They may be diesel but still not very economical. They use about 12L/100km in metro.
You should be able to get this for closer to $15000.
Lots of different options with these.
They are based on the Pajero and share lots of parts.
The only bad point is.........it is a Mitsubishi (Mitsushitty)
Cheers
Andy
Thankz everyone for thier inputs!
Im still thinking which one to go for atm...But I got a smile on my face when i drive my stag every morning!
i like the new elgrand, it looks hot but then not sure if i gona pay extra for a bigger car..since bigger = harder to park..
Craig, the Delica is a good car...since it share alot of parts with the pajero means u will never have problems with parts either factory or after market..
but the problem with this car is they are too tall, they are like 2.2 meter up, and ur wife will find alot of problems trying to get into parking either under ground or at shoping centre,
my friend have one before he used to complaint to me all the time....
rofl i think craig is joking.......
nah...that Delica is hot.....even better that picture is what sold her on them....it's better than an old Tarago or most other people movers.
only let down.....it's a 04 to 05 Mitsashitty!!!
Since reading this thread I've seen at least 3 elgrands driving around in Brisbane.
Then I made the mistake of showing the mrs......now she wants 6 kids :thumbsup: (so that we can buy an elgrand...i told her just 4 would be enough to outgrow the stagea...but even so...we've only just had our first)
She still reckons the M35 is ugly but she thinks the elgrand looks great....?!
I dont mind the look of the elgrand, but the stagea is here to stay. Unless they make the elgrand awd & turbo or otherwise fit a VQ37HR into it...
Edited by pixel8r
El Grand is 4wd and some have a VQ35DE in them (E51) E50 commonly has a Turbo 4cyl in them with the VQ30 or VG33 in them.
I believe 4wd is an option, and from my (limited) reading, not a very common one? At least with the latest ones from the Nissan Hong Kong website, it specifically says front engine, RWD.
VQ30 is V6.
interestingly if they had a VQ30DD it would have more power than the VQ35DE. In my opinion the VQ35DE is the weakest part about it. They use the severely detuned 170kw version, not the 220+kw version that the 350z had (might be thinking of the VQ35HR but either way the VQ35DE is capable of 206kw & 360N-m).
indeed! i think the engines are identical, its probably just injectors and engine timing. besides all the manifold stuff.
but why do it to a FWD maxi?? its gonna torque steer its tits off!
lol... I was referring to the engine... not the car.
Having said that, have you driven a TRD Aurion? Stuff all torque steer there bud. Must have something to do with intelligent engineering...
nah im not into high powered FWD cars. the most was my euro and it was torquey enough for me with only 140kw. gimme RWD anyday!
mind you, i could throw the honda into a corner and it would be VERY comfortable lol
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
