Make/Model: Toyota Hilux duel cab
Year: 1987
Kilometers: 372xxx
Transmission type: Manual
Engine: 1800 i think lol
Colour: White
Modifications: stockie rockie
Roadworthy Certificate: N/A in SA
Accident History: few dents
Asking Price: $1000 quick sale cos i need cash for my skyline!
Contact Details: Call or message me 0433174833 or pm me
Other Comments:
Ive had this car for about 6 months and she hasnt missed a beat, been driving to work back and forth 5 days a week.
Has a hole in the zorst which will cost about $100 to fix and the idle jet on the carby aint the best (idles a bit dodgy) but still easy diveable, brakes and stuff are all fine.
Im selling this car cos im getting a new toyota hiace van to try and push my tax down.
Edited by datto_sw
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
