Hi all,
I've got a relatively stock r33 (turbo back exhaust) and have been consideirng the following mods:
FMIC (something that would sit under a stock s2 front bar)
POD (with a pod box if i can find one!)
upping the boost 10-11 or so max
As I live in NSW and need rego checks every year I was wondering whether any of these would cause me a problem?
Would I need engineers for any of it? if so what would that roughly cost?
Also anyone think these mods would affect reliablity given that it is my daily driver?
thanks!
https://www.sau.com.au/forums/topic/277638-nsw-mods-rego/
You will pass rego with those mods although FMIC and pod wont sit well with PO PO ie they are defects.
You should go for a FMIC that doesnt require any cutting of the battery tray, i think u can get them from Just Jap. For the filter just run a hi flow panel filter or if u are adamant on running a pod run it hidden in the bar
https://www.sau.com.au/forums/topic/277638-nsw-mods-rego/#findComment-4695078
Thanks for the reply.
I don't get that, as if I do get defected don't i go back to the rego check place to get defects cleared?
Yeah really after a fmic that will need little to no cutting to the stock r33 s2 bar or anything else (anyone have suggestions?)
So if Pod is in a proper box (fully concealed) then this should be ok as it is out of view?
cheers
https://www.sau.com.au/forums/topic/277638-nsw-mods-rego/#findComment-4695228
