hi, i am newbie here -- thanks for all the info posted. just bought a 2001 ar-x with 160k, mint condition but the turbo is whistling.
what r the best options.
how much to replace with a good aftermarket jobbie?
and with 160k on the clock is it silly to go for something with more power?
any recs for a good turbo?
can anybody in auckland recommend a good shop? also there are some suspension awd drive issues... if anybody in auck could txt me on 027 202 1996 i would appreciate it.
https://www.sau.com.au/forums/topic/277649-new-turbo/
You may find the whistling is normal, best to find someone else with an M35 in NZ and let them hear it, it may just well be the normal noise that the turbo makes while operating.
Best options if you have a look at the turbo thread we started not long ago (it's got some good information in there) is to high-flow the existing Garrett that is on the car. The turbo is located in such a tight hot space under the bottom of the engine that not much else will fit or function there.
Jetwreck has just high-flowed his in the last few months and from memory he is now over the 100 000k mark. Just depends if the car has been looked after and you think you are going to get a few years more use out of it a high-flow would be ideal :yes:
https://www.sau.com.au/forums/topic/277649-new-turbo/#findComment-4695280
Jetwreck has just high-flowed his in the last few months and from memory he is now over the 100 000k mark. Just depends if the car has been looked after and you think you are going to get a few years more use out of it a high-flow would be ideal :)
thanks for taking the time and trouble with your reply -- much appreciated
https://www.sau.com.au/forums/topic/277649-new-turbo/#findComment-4697295
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
