Hey all!!!
Just wondering where your siren is for your alarm? I have an r33 and the noodle that fitted the alarm put the siren in the drivers side shock tower, pointing down towards the front of the engine.
In this position it doesnt seem very loud, i am lucky to hear it go off from inside my house. the alarm is a rhino maybe all rhinos are quieter???
https://www.sau.com.au/forums/topic/27767-where-is-your-alarm-siren/
No no one said it was bad. It just is a hell of a lot louder when the bonnet is up, obviously.
but in the manual for the alarm it said it should be mounted on the fire wall pointing down. Not a lot of room there on the r33, I could move it to there but i am a bit scared of drilling thru the fire wall into some wiring or something.
it just seems where it is the sound is muffled by everything in the engine bay. I thought it would be louder if the sound was bouncing straight of the ground underneath the car maybe??
Any ideas??
that is the best place for it... if they're too close to the exposed area, the thief will simply crawl underneath and reach up to snip the wires..before they do the rest of the car.
seems a little soft, with my bonet closed i can hear mine clearly 50m or so away.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
