nismo... these cables are Mbus cables, ie serial over USB or pure serial. Wheras the genuine nokia ones are Fbus. Non fbus cables won't work with data suite software. Next time we meet up remind me n i'll bring you a "special version" of OPM2 :rofl:
  • Replies 61
I did have an Fbus with my last fone [6210], i didnt know the type i bought wasnt compat with data suite but no matter oxygen looks good so far - hmm special version :D
funkymonkey, Im not talking about serial cables, if you read description my cables are usb (the modern era).
circuit central sells them for $74.95 so please do some research before wasting peoples time.
cheers
my bad, this is the one that I was after...
http://www.circuitcentral.com.au/shop/cust...productid=18573
If you can do a better price than 45 bucks I'll grab one off ya serious, I'm not tryin 2 waste ur time.
NismoR34 The one I posted before was serial, which is a lil slower than the USB version. Its called a pop port cable coz the connector is called a pop port (ie a shitload of pins more than a normal cable)
btw if you did a speed test of a serial vs a usb you'll find that the transfer speed differs by 115bps. reason being the chip in the usb cable (the one in the lil box in the middle of the cable) simply converts serial data into the neccessary pinouts of a USB. Its basically like using a really good serial cable. Its not modern era, its just a different plug. Mbus by design is a serial data transfer protocol with error correction.
ok, it looks like i am posting basic queries but I AINT!
on the circuit central web it said that those pop port cables - the 34.95 ones were NOT compatible with the nokia data suite, so they must not be dku-5 compat?
I always thought that pop port meant the type of connector but how can you actually tell which are compat and which are not - i guess thats the real question...
doesnt matter much now neways
Mr Twinturbo, anychance if you could show me how or where to down load the software for my GD88? anyone?
Got your cable and stuffs but on the CD, there is only the driver and that it. I need the software to run it.
Cheers
Thanks
west : go to the following website :
http://www.matweb-01.com/English/dls-fds.htm
Alternative also for the E365 :
http://www.gsm-technology.com/gsm.php/en,d...d,Motorola.html
and download the appropriate handset manager for your phone.
Thankyou
regards
    • Definitely didn't put a N/A cluster in instead? The speed sensor (location) is different in both cars.... I think. This will obviously stuff things up.
    • Nah not the throwout bearing, it's something internal. I already replaced the throwout bearing. Mechanic misdiagnosed my car and thought it was a spigot bearing, went to another bloke who said it was an input shaft bearing. (I replaced everything when I pulled out the gearbox but didn't open up the gearbox.   In this video at timestamp 6:05 : Mine has the same sound  min
    • It is definitely to space it out and away for clearance during compression, and possibly for spring clearance to upper arm. That latter would only be true for springs that are same-ish diameter to stockers, and so that probably doesn't apply to Teins or most other coilovers.
    • Yeah, a mechanic who knows these cars told me even if I get a brand new gearbox the noise will return but will be less noticeable. I've heard someone also they this noise came back after 3,000km on a new or reconditioned gearbox. It is pretty f**king annoying though just hearing groaning most of the time lol. I wonder if an aftermarket input shaft bearing would fix the problem or how they are built.
    • All RB gearbags, especially the big turbo box, have rollover noise. Mine certainly does. Always has. Sometimes is worse than others - no particular idea why, although it is probably temperature related. I have smurf jizz in mine and have had to have it in there from the first day the box went into teh car. It simply would not select gears with the engine on, on day one, with normal oil in there. And so, the blue stuff has probably ruined almost everything synchro related in the box. But it has taken 12 or 13 years to get to the point where I simply must replace the box. It has become increasingly baulky of late, which might be symptomatic of the way I've been driving it, as much as anything. I shall have to make some corrections when teh new box goes in. Input shaft bearing noise will decrease with clutch pedal pressed because the drive is removed. But yes, more often than not noises that work like that are associated with the throwout. It won't matter either way, new box will mean this one can be relegated to the parts pile.
