hey all wat is the speed cut set at and how can you override it as my vl cuts out at 180-190km/h oh and its a race car not a street car so i can reach those speeds thanks
The Skyline ECU is speed limited to 180km/h.
To bypass this, cut the YELLOW/GREEN wire at the ECU which is pin number 53. This wire sends the speed input to the ECU. You won't be running HICAS so this won't affect the steering at all.
thanks for that man its a pain in the ass hittin the limit halfway down the straight at qr
101 W/L Injector # 1 Control Signal
102
103 W/R Injector # 3 Control Signal
104 LG Fuel Pump Terminal Voltage Control Output (FPCM) 1
105 Y Injector # 2 Control Signal
106 G/W Fuel Pump Terminal Voltage Control Output (FPCM) 2
107 B/R Injector Ground
108 B/R Injector Ground
109 B/W Injector Power Supply (Counter Electromotive Reflex Circuit)
110 W/G Injector # 5 Control Signal
111
112 W/B Injector # 6 Control Signal
113
114 W/L Injector # 4 Control Signal
115
116 B/R Injector Ground
1 L/O Ignition Signal # 1
2 L Ignition Signal # 5
3 L/R Ignition Signal # 3
4 L/G AAC Valve
5
6 B Sub Electrical Fan Relay (Engine Temperature Switch)
7 Y/R Tachometer Signal Output
8
9 L/G Air Conditioner Relay (AC Cut Signal)
10 B/Y Ignition Signal System Ground
11 L/W Ignition Signal # 6
12 L/B Ignition Signal # 2
13 L/Y Ignition Signal # 4
14
15
16 O ECU Relay
17 Injection Pulse Signal (Ti Monitor)
18 B/P Fuel Pump Relay
19 SB Power Steering Oil Pressure Switch
20 B/Y Ignition Signal System Ground
21 Y/G Receive (Control Unit Data Reception) RX
22 Y Transmit (Data Sent From Control Unit) TX
23 W/R Detonation Sensor (Cylinders 1-3)
24 W/R Detonation Sensor (Cylinders 4-6)
25 L/Y Wastegate Valve Control Solenoid Valve
26 W/R Air Flow Meter Ground
27 B Air Flow Meter Intake Air Quantity Signal (Rear)
28 Y/G Engine Temperature Sensor Signal
29 Clear Exhaust Gas Sensor Signal (Front)
30 B Sensor Ground (tps, Coolant Temp.)
31 Y/R Clock (Synchronization Signal) CLK
32 O/B Malfunction Indicator Lamp
33
34 W Air Flow Meter Ground
35 O Air Flow Meter Intake Air Quantity Signal (Front)
36 SB Intake Air Temperature Sensor Signal
37 Air Flow Meter
38 W Throttle Sensor Signal Opening Output
39
40
41 G/B Crank Angle Sensor (120 Degree Signal)
42 G/Y Crank Angle Sensor (1 Degree Signal)
43 B/Y Ignition Switch (START Signal)
44 G/O Neutral Position Switch
45 B/R Ignition Switch (IGN)
46 LG/R Air Conditioner Switch Signal
47 Y/PU Check (Diagnosis Activation) CHK
48 Y Throttle Sensor Power Supply
49 B/W ECU Power
50 B ECU Ground
51 G/B Crank Angle Sensor (120 Degree Signal)
52 G/Y Crank Angle Sensor (1 Degree Input)
53 Y/G Vehicle Speed Sensor
54 LG Throttle Valve Switch (Idle Contact Point)
55 Clear Exhaust Gas Sensor Signal (Rear)
56 PU Throttle Sensor Output Signal
57 G/R Throttle Valve Switch Power Supply
58 W/B Battery Power Supply
59 B/W ECU Power
60 B ECU Ground
