hey all wat is the speed cut set at and how can you override it as my vl cuts out at 180-190km/h oh and its a race car not a street car so i can reach those speeds thanks
The Skyline ECU is speed limited to 180km/h.
To bypass this, cut the YELLOW/GREEN wire at the ECU which is pin number 53. This wire sends the speed input to the ECU. You won't be running HICAS so this won't affect the steering at all.
thanks for that man its a pain in the ass hittin the limit halfway down the straight at qr
101 W/L Injector # 1 Control Signal
102
103 W/R Injector # 3 Control Signal
104 LG Fuel Pump Terminal Voltage Control Output (FPCM) 1
105 Y Injector # 2 Control Signal
106 G/W Fuel Pump Terminal Voltage Control Output (FPCM) 2
107 B/R Injector Ground
108 B/R Injector Ground
109 B/W Injector Power Supply (Counter Electromotive Reflex Circuit)
110 W/G Injector # 5 Control Signal
111
112 W/B Injector # 6 Control Signal
113
114 W/L Injector # 4 Control Signal
115
116 B/R Injector Ground
1 L/O Ignition Signal # 1
2 L Ignition Signal # 5
3 L/R Ignition Signal # 3
4 L/G AAC Valve
5
6 B Sub Electrical Fan Relay (Engine Temperature Switch)
7 Y/R Tachometer Signal Output
8
9 L/G Air Conditioner Relay (AC Cut Signal)
10 B/Y Ignition Signal System Ground
11 L/W Ignition Signal # 6
12 L/B Ignition Signal # 2
13 L/Y Ignition Signal # 4
14
15
16 O ECU Relay
17 Injection Pulse Signal (Ti Monitor)
18 B/P Fuel Pump Relay
19 SB Power Steering Oil Pressure Switch
20 B/Y Ignition Signal System Ground
21 Y/G Receive (Control Unit Data Reception) RX
22 Y Transmit (Data Sent From Control Unit) TX
23 W/R Detonation Sensor (Cylinders 1-3)
24 W/R Detonation Sensor (Cylinders 4-6)
25 L/Y Wastegate Valve Control Solenoid Valve
26 W/R Air Flow Meter Ground
27 B Air Flow Meter Intake Air Quantity Signal (Rear)
28 Y/G Engine Temperature Sensor Signal
29 Clear Exhaust Gas Sensor Signal (Front)
30 B Sensor Ground (tps, Coolant Temp.)
31 Y/R Clock (Synchronization Signal) CLK
32 O/B Malfunction Indicator Lamp
33
34 W Air Flow Meter Ground
35 O Air Flow Meter Intake Air Quantity Signal (Front)
36 SB Intake Air Temperature Sensor Signal
37 Air Flow Meter
38 W Throttle Sensor Signal Opening Output
39
40
41 G/B Crank Angle Sensor (120 Degree Signal)
42 G/Y Crank Angle Sensor (1 Degree Signal)
43 B/Y Ignition Switch (START Signal)
44 G/O Neutral Position Switch
45 B/R Ignition Switch (IGN)
46 LG/R Air Conditioner Switch Signal
47 Y/PU Check (Diagnosis Activation) CHK
48 Y Throttle Sensor Power Supply
49 B/W ECU Power
50 B ECU Ground
51 G/B Crank Angle Sensor (120 Degree Signal)
52 G/Y Crank Angle Sensor (1 Degree Input)
53 Y/G Vehicle Speed Sensor
54 LG Throttle Valve Switch (Idle Contact Point)
55 Clear Exhaust Gas Sensor Signal (Rear)
56 PU Throttle Sensor Output Signal
57 G/R Throttle Valve Switch Power Supply
58 W/B Battery Power Supply
59 B/W ECU Power
60 B ECU Ground
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
