Just a quick gotcha - Sonic silver (not the actual code 'KR4', but the name of the colour) is used post 2002, but is a different tint. Be sure to use the code & the name when obtaining paint.
oh ok. i thought that was the name for the silver on the R34's and S2 stagea's. what is the name for the silver on the stagea's then?
this site is usually a help but doesn't list sonic silver. nissan colour codes
https://www.sau.com.au/forums/topic/277740-paint-codes/#findComment-4699460
Sorry, I may not have explained properly;
KR4 (Sonic Silver) is the correct colour for the C34.
BUT
There is another Sonic Silver used in later model cars that is not correct (I don't know the code offhand).
any idea where to get some KR4? ive tried two nissan dealers here in adelaide another paint supply place and they can't help me. Ive got a reasonable scratch in the front quarter panel i need cleaned up and would rather have the panel panted rather then just touched up.
help please!!!!!!!!!!!!!!!!!!!!!!!! :down:
https://www.sau.com.au/forums/topic/277740-paint-codes/#findComment-4700383
I bought a 1 litre a while ago for a series 2 to respray the engine bay. Only used half of it. No longer need it, but I am in Brisbane
Just the 2 pac base coat alone was just over a $100/litre in a good brand
Any car paint supplies should be able to mix it up.
According to Glasurit paints there is one version from 1996-2002
http://www.glasurit.com/COLOR/new-color-on....php?language=1
https://www.sau.com.au/forums/topic/277740-paint-codes/#findComment-4700618
help please!!!!!!!!!!!!!!!!!!!!!!!! :)
I've only recently bought a small pot of touch-up and one pressure pack (with clearcoat mixed in) from Lonsdale Paint Supplies. I just asked for some KR4 Sonic Silver & a day later it was ready.
https://www.sau.com.au/forums/topic/277740-paint-codes/#findComment-4701218
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
