hi
r34 gtr front seats forsale
650 for the pair
location brisbane
pm me
thanks russell
If the seats are in good condition, I'll buy them if they are still for sale. Im also in Brisbane. Do you have any pictures of them? Cheers
hi guys
i just want to apologize, as the seats have been taken off sale for the moment , as mark in his wisdom wants to make office chairs with them!!
i am trying to talk him into using the r35 seats but he recons there too heavy.
anyway sorry for the time wasting.
if i can get him to agree , i will repost forsale.
the seats are genuine r34 gtr seats out of the car that we turned into this
the seats are in pretty good nick.
cheers russell
  • 1 month later...
If they're genuine 34 gt-r seats I'll happily give you a thousand bucks and arrange pick up! Sounds almost too good to be true!
It was people already laying for that seats for 650 $ so what did You try to offer 1000 for them is disgusting .You f**ken stingy flamin mongrel You know they are worth 2500 - 3000 .So just stick to your ripping off business .
That is rather rude. :cool:
yeeeh a little bit too far dude
and i'd argue your window of opportunity to leave such a remark closed sometime in july :D
Warning issued.
Post a comment like that on the forum again and you are banned.
Guest
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
